Question about Dell Studio 17 Laptop
Need to find the inverter on my dell studio laptop
  • joecoolvette
    joecoolvette May 25, 2011
    cobra2949, if you need the Service Manual for information on how to access the Inverter on your Dell Studio laptop, let me know in a Comment. Regards, joecoolvette
  • 1,188 Answers
It is at the base of the screen, right below the LCD. Here is a diagram:
http://blog.parts-people.com/2011/04/04/dell-studio-1535-1536-1537-lcd-inverter-removal-and-installation/
Let me know if you need further assistance. Changing the inverter isn't very difficult.
Good luck!!
EJ Kudelka
Posted on May 25, 2011
Dell STUDIO 1537 black screen on first boot up ??
The inverter maybe faulty, it supplies high voltage to the CCFL lamp and would cause the screen to be black.
Since it was just repaired, I suggest you return it to Dell to have it repaired under warranty.
May 09, 2012 | Dell Studio 1537 Notebook
Dell studio 1555 won't power up. LED flashes 4 orange, one white.
First, check the RAM.. If possible replace it by a good one for testing or clean the pins of the old one using clean paper.
Second, its processor...
Third, maybe it is the inverter of your LCD display or the whole LCD. Test it using external monitor by plugging your data cable to it monitor port.
May 01, 2011 | Dell Studio 1555 laptop
What is the most common problem with A Dell Studio 1537 LED backlit LCD not lighting up?
LCD inverter board. They're pretty simple to replace and cost only bout $10-$15 on Ebay. If you do it yourself just be careful taking off the plastic bezel from the screen.
Jun 09, 2010 | Dell Studio 1537 Laptop
Dell Studio 1537 laptop will not power up.
Did you recently changed the system configuration? if so you need to reset it to the default value from the bios or you remove the Bios Battery leave it for few mins and reinsert it, if you can't even boot up to this, then remove the HDD and see whether you can access your bios or not. Good luck..
May 04, 2010 | Dell Studio 1537 Notebook
The screen will not come on when the computer comes on on my dell xps notebook. The laptop comes on but the screen stays black when turned on.
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at http://www.insidemylaptop.com/remove-replace-lcd-screen-video-cable-inverter-on-dell-laptops/ . Hope this helps you out a bit...
Mar 29, 2010 | Dell Studio XPS 16 Notebook
I have a problem with my dell studio 1535 lcd.i guess the problem is with the inverter.how t check whether the inverter is working by using an ammeter
1 check if the battery is still good by switching the meter to DC and test it if it is still reading the correct voltage.if not the batteries may be bad
2. switch it to AC and check the out put if it is supplying a voltage output.if not the transistors may be bad
Mar 04, 2010 | Dell Studio 15, Studio 17 175-Watt Power...
My C610 Dell has a screen that is a little darker than it should be. Would this likely be the backlight or inverter. Should both be replaced at the same time as a matter of standard procedure? T R
Have you tried adjusting first the brightness level? If nothing happens when adjusting it, the LCD and LCD cable needs to be replaced. If im not mistaken, i believe there is no backlight/inverter that can be replaced since its already built in the LCD. Some Dell laptops have inverters like Studio 1737 that can be replaced. Hope this helps
Dec 08, 2009 | Dell Computers & Internet
Dell Studio 17 Laptop Logo
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
