Question about Good Technology Good for Enterprise
I have downloaded the Good Enterprises application to my iphone 3GS. I also have been set up by my IT department. When I go throught the process of setting up it freezes/gets stuck on the window: Setup Setup Progress Status: Starting Services
Need to download iOS 5
to update to iOS 5 is only possible on iPhone 3GS / 4 / 4S with connecting the device to iTunes on a computer.
- Plug the iPhone to your computer and open up iTunes under devices click on your iPhone and then click on check for update.
latest iOS possible:
iPhone 1 = iOS 3.1.3
iPhone 3 = iOS 4.2
iPhone 3GS = iOS 6.1.6
iPhone 4 = iOS 7.1.2
iPhone 4S = iOS 8.1.2
iPhone 5 = iOS 8.1.2
need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-0.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-2.jpg need-download-ios-5-rb1lxwwedrgyiycdlihok4mn-5-5.jpg
Mar 19, 2014 | Cell Phones
Tip
How to jailbreak iOS 4.3.1 using redsn0w on a PC (Windows) or a Mac
This will guide you on hactivating and jailbreaking the following iDevices with iOS 4.3.2, 4.3.1, 4.2.1 or earlier:
  • iPhone 4
  • iPhone 3GS
  • iPod touch 4G
  • iPod touch 3G
  • iPad
The jailbreak will be untethered, meaning you don't have to worry about rebooting your iDevice.
Download redsn0w 0.9.6rc14 for jailbreaking iOS 4.3.2, links below: Use version 0.9.6rc12 if you have iOS 4.3.1 installed on your iDevice. CLICK HERE to download that and all earlier versions of redsn0w.
Here are the links to download the 4.3.2 IPSW files. If an Ad appears, just click SKIP THIS AD on the top left corner to continue on downloading:
You can also try locating it locally on your computer. For Mac, go to:
Users>HOME FOLDER>Library>iTunes>iPhone Software Updates>
For Windows, go to:
C>Documents and Settings>HOME FOLDER>Application Data>Apple Computer>iTunes>iPhone Software Updates>
NOTE (For PC users): Application Data is a hidden folder, make sure to set hidden files visible from Control Panel>Folder Options>View>
WARNING: The following basebands are still UNLOCKABLE. DO NOT UPDATE to iOS 4.3.1 (or higher) if you need the unlock:
  • 05.14.02 - iPhone 3G & 3GS, iOS 4.1
  • 05.15.04 - iPhone 3G & 3GS, iOS 4.2.1
  • 05.16.00 - iPhone 3GS, iOS 4.3 and 4.3.1
  • 05.16.02 - iPhone 3GS, iOS 4.3.2
  • 03.10.01 - iPhone 4, iOS 4.2.1
  • 04.10.01 - iPhone 4, iOS 4.3 and 4.3.1
Update iTunes to 10.2.1 for best results.
Procedure:
  2. Turn OFF your iDevicekid_ant_9.pngTo turn OFF, press and hold the POWER button for about 3 to 5 seconds then slide the red bar on top of your iDevice's screen saying "slide to power off"kid_ant_9.png
  3. Open/Run redsn0w and click Browsekid_ant_9.pngNOTE: The screenshots you'll see here are taken from a Mac and earlier version of redsn0w, however, the process is completely the same if you'll be working on a PC (Windows) or a newer version of redsn0w.kid_ant_9.pngb3f2d73.png
  4. Locate the official IPSW.kid_ant_9.pngUse the following:kid_ant_9.png4.3.2 IPSW if you have iOS 4.3.2 on your iDevicekid_ant_9.png4.3.1 IPSW if you have iOS 4.3.1 on your iDevicekid_ant_9.png4.2.1 IPSW if you have iOS 4.2.1 on your iDevicee07dd38.jpg
  5. redsn0w will process and identify the IPSWkid_ant_9.png6906b9a.pngkid_ant_9.png93adf2e.png
  7. Check on Install Cydia and click Nextkid_ant_9.pngb046af5.pngkid_ant_69.jpgb046af5.pngClick image for larger view.b046af5.png
  8. Turn OFF your iDevice (just a reminder from step 2). Before you click Next, read steps 9 to 11 first in preparation for putting your iDevice to DFU moded3f7cae.png259a3f7.png
  10. Continue holding down the POWER button then press and hold the HOME button as well. Hold them both for another ten (10) secondsa143c2c.pngf115990.png
  12. You can release the HOME button once you see redsn0w in the process of jailbreaking your iDevicekid_ant_9.png0c41e1b.png
  13. Click Finish and you're done on the computer, and as it says, the rest takes place on your iDevice.kid_ant_9.png7aba1b9.png7c880f5.png4beff7a.png
All you need to do now is wait and keep it plugged in your computer. DO NOT INTERRUPT!kid_ant_9.png
Once complete, you will find Cydia on the 2nd page of your iDevice's homescreen and it should operate as usual.
If you have an iPhone and you're able to preserve your baseband, you can CLICK HERE to UNLOCK.
Credits:
iPhone Dev Team
kidantvideos
on Apr 04, 2011 | Apple iPhone Smartphone
Tip
Jailbreak or Unlock iPhone 4/3Gs/3G in a Minute
Apple fans have been waiting for a newJailbreak and a Carrier Unlock for the new iOS 4.2.1, and the iPhone Dev Teamhas released the goods. It may not be simple, but at least a solution isavailable. One of the most fortunate thing was that the newer upgradedid not update the baseband, and so the baseband remained at 05.13.04. So u<b><span>nlock and jailbreak foriPhone 4, 3G and 3Gs</b>becamemuch more easier, however the good thing is that iPhone 4,3G,3Gs can beunlocked and jailbroken on the iOS 4.0.2/4.1 or 3.1.3 at the moment, becausethe current jailbreaking & unlocking tools are compatible with iOS4.0.2/4.1 or 3.1.3. Unlocking Ltd. has introduced a fresh iPhone unlocksoftware that will allow users to explore their Apple iPhone's customizationand application capabilities. Specifically, it can "unlock and jailbreak iPhone4.2.1, 3G 3Gs and iPhone 4 4.2.1."</span> The veryfirst unlocking software for iPhone was unlocked by iPhone Unlocking Ltd inJuly 2007. More than one million customers from more than 145 countries havedownloaded the software. Additional features are added to a mobile phone, thanksto jailbreaking and unlocking has become a trend among iPhone users. Users canalready explore the various functions of their iPhones once it has beenunlocked and jailbroken. If we are mac users, we can put dvd to iphone 4 by a<a href="http://www.dvdtoiphone4.com/mac-dvd-to-iphone-4.html"> dvd to iphone 4mac</a> converter after our jailbreaking, you will find it is so easy for us to<a href="http://www.dvdtoiphone4.com/guides/convert-dvd-to-iphone-4.html">convertdvd to iphone 4</a>. Now we can jailbreak or unlock iPhone4/3Gs/3G with the latest tool that allows iOS jailbreak 4.2.1/4.1 and thatis compatible with Cydia and MobileSubstrate as easy as ABC. As you've said,this jailbreak is compatible with all models of iPhones but to differentdegrees. The new tool available at UnlockGuide website is very simple to useand guaranteed to jailbreak and unlock iphone4/3GS/3G running iOS 4.2.1 orolder versions. Owners of the popular iPhones will now beable to unlock the very latest ios 4.2.1 for iPhone 3G and iPhone 4. The firstsolution to jailbreak was announced by iPhone Unlocking Ltd. Unlocking a mobilephone is not the same from jailbreaking even if both provide users additionalbenefits to an iPhone. When a buyer purchases an iPhone, it is fixed or lockedbased on what the manufacturer has provided in terms of its exclusivefunctionalities. What's more, any GSM card will be compatible with the softwarebeing offered by iPhone Unlocking Ltd., and the features are also compatiblewith the latest baseband worldwide. User will be able to use any networkprovider from anywhere in the world once they have unlocked their iPhones. If you have a newer model (iPhone 3G andnew iPhone bootrom 4), your <a href="http://www.dvdtoiphone4.com/guides/jailbreak-iphone-4.html">jailbreak iphone4</a> will be tethered. Indeed, if you have not installed any applications thatinterfere with the functioning of the SpringBoard or CommCenter, your iPhonewill boot up correctly. However, if you have installed applications thatrequire MobileSubstrate (Infiniboard example) and that interfere with thenormal operation of SpringBoard, your iPhone will remain stuck on the Applelogo at startup. We also remind those wishing to conserve or unlock unlocktheir iPhone, it should not be used redsn0w and update your phone iOS 4.2.1. Makethe update via iTunes 4.2.1 iOS 10.1 (this is important) using the firmware youjust downloaded (Hold down the Shift key on Windows, then click Update andselect the file. ipsw you downloaded).<br /><br /> <br /><br /> <img src="clip_image001.gif" />
on Nov 30, 2010 | Computers & Internet
How to unlock iphone 3gs
Jailbreaking is entirely different from unlocking . Jailbreaking is the process of removing limitations/restrictions so that 3rd party applications can be installed. Unlocking a phone is a procedure to remove any SIM/Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider.
To unlock your iPhone 3GS you can get Remote Unlock Service from Mobile-Unlocker.com . There you have to give your Country and current Network name along with your IMEI number to get Remote Unlock Service.
Jun 01, 2013 | Apple iPhone Cell Phones
Iphone 3gs downgrade from 6.1 to 6.0.1
u can restore it with last backup which had version 6.0.1 then it will be downgraded. but make sure that u have the same information in the old backup otherwise u save ur contacts (most important info.) to the outlook and then do the process.
good luck
Feb 14, 2013 | Apple iPhone 3GS Black (16 GB)
Tip
How to unrestrict you iPhone 3GS to make Voip calls over the 3g network!!!
First of all, you'll need an iPhone 3GS (of course). This trick works for the version 3.1.2 of Apple's firmware. First, you'll need to jailbreak your iPhone 3GS. For that, you'll need to download the blackra1n.exe application from this website: www.blackra1n.com, then you'll need to run the application (nothing complex, just a one-button-easy-process) and wait for your iPhone to reboot (note that after this you won't be able to shutdown your iPhone again, as this is a tethered jailbreak, if you do, it'll restart in restore mode and you'll need to manually boot it again with the blackra1n program). When the jailbreak is done, you'll see a black-drop-shaped icon in the application list on your iPhone, tap it and install the cydia and Rock applications. When you finish installign those, tap the Rock application and then tap on "manage" at the right bottom of your screen. After that, tap "Manage Sources", then "Edit" (top-right of the screen), then "Add" (Top-left), then type exactly this: "http://sinfuliphonerepo.com" (without the quotes). Now, after confirmation, still in Manage>Sources, scroll down until you see a section called "User entered". Tap the arrow to show a list of applications. The first one should be an application called "3G Unrestrictor", install it. After installed, open the application from your springboard and select these application if you have them: Skype, Nibuzz, App Store (Choosing it also unlocks iTunes Store) and any other application that doesn't allow a certain type of connection over the 3G network system. And as a bonus, you might grab some other free applications for your iPhone, such as old game consoles emulators, file managers (iFile Cracked) and more!
on Feb 06, 2010 | Cell Phones
Why cant I download ios 5 for iphone 3gs
The iPhone 3GS does support iOS 5 and even the latest iOS 6. However iOS 5 is no longer available for it by Apple's choosing, but the good news is that iOS 6 works well on the 3GS as tested
Oct 13, 2012 | Apple iPhone 3G
Att iphone 3gs factory unlock code want to use w tmobile service
Hi, You can unlock your iPhone 3GS safer and easier through remote unlocking method. You can get the remote unlocking for an iPhone 3GS from www.unlocking4u.com/apple-iphone-3gs/rs6wp9/ at affordable cost. This process of unlocking is very simple.
Here are the steps for unlocking an iPhone 3GS through remote unlocking method,
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 3GS phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 3GS to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 3GS.
6. Disconnect your Apple iPhone 3GS and reconnect it after 10 seconds.
7. Your Apple iPhone 3GS is now unlocked.
Sep 22, 2012 | Apple Iphone 2g 3g 3gs 8gb 16gb S
How can i install an apps in my iphone 3gs using itunes
Plug iPhone into mac.Open iTunes.Download applications in iTunes.Set iPHone to sync applications with iTunes.
Sep 03, 2012 | Apple iPhone 3GS Back Case Black ...
To unlock the iphone 3gs so that it can accept other sim cards
  1. Jailbreak your iPhone
  2. Go to Cydia application, search for Ultrasn0w
  3. install it
  4. You should be good to go!
Dec 30, 2010 | Apple iPhone 3GS Black (16 GB)
Good Technology Good for Enterprise Logo
2,348 people viewed this question
Top Good Technology Apps Experts
shuyumeng
shuyumeng
Alan Gsm
Alan Gsm
Are you a Good Technology App Expert? Answer questions, earn points and help others
