Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
My freezer is working properly but my fridge is warm
  • 54 Answers
Check the back wall of your freezer, see if you notice any ice built up.. or bottom of freezer in the back where the water drain out when your freezer goes into defrost.. or make sure there are no obstruction by the vent grill in your freezer...if you have ice built up then, you would have to unplug your freezer to let it thraw out.. clean out drain hole.. if completed thraw out and your coil ice up again.. then , of 3 problems.. low refrigerate, fan motor, or defrost sensor... help that will do it.. good luck ,. mike
Posted on Jan 23, 2009
Compressor working fridge is not
Not a 5 min. explanation, but in short, if the compressor and fan are both running, question is, Is the freezer cold but not the fridge? If so, defrost properly for approx. 12 hours to remove all ice then restart. If not, one of 2 options remain, there is either a Blockage in the system, or there is a leak in the system. Either way, you need to call a service technician. Truthfully, if diagnosed with a leak, i suggest you replace the fridge as these leaks do not get repaired properly especially if it is internal and good money will get wasted. Hope i helped.
Jul 29, 2013 | Whirlpool 19.6 cu. ft. Upright Freezer...
Amana fridge freezer AS2628HEKB fridge warm & freezer frosty inside
The board should be replaced before the unit will operate properly. Be sure to check out all circuits to make sure there is not some kind of short. If there is, it may burn out the new board also.
Jan 21, 2013 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge warm, freezer working, pump working. where
Either the thermostate is defective or refrigerent blocked or leaked or the relay is not functioning properly. Only on inspection of the above parts could pronounce the right remedy.
Jul 06, 2009 | Refrigerators
What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
157 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
