Question about Liebherr Refrigerators
Hello, there is a leak of water around the door of my Liebherr refrigerator. More specifically the water comes out from the rubber around the inside of the door (from a little round hole)
  • eleanaalikak May 27, 2011
    After following the instructions the leak stopped and the problem no longer exists. Thank you!
  • 4,066 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on May 25, 2011
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
Mazda Bt50 cab leaks on drivers side
I recently purchased a 2008 BT50 dual cab then 2 days later we had 500mm of rain and of course it leaked :( I had about 80mm of water on the drivers side floor and 30mm on the passenger side floor. I stripped the interior out of the car and started hosing the outside and watching where it was coming in. I took all the windscreen surrounds off and the cowl panel off below the screen there was no water coming in from that area. I had taken the gutter seals off but left the door seals on so the water was running down around the outside of the seals (with the door shut) and out at the bottom. From inside near the drivers side kick panel I could see water coming through seams in the metal work and when I took the door seal rubber off the body on the car I could see water was getting in at the top of the door seal rubber going down the front inside edge of the rubber and getting in through the seam where the rubber push's onto the body of the car (first problem). I took all the door seal rubbers off and run a bead of non corrosive silicon inside the cavity and pushed them back on. It seemed to have fixed the problem I dried the carpet and put it back together..Two weeks later we got another 325mm of rain and it leaked again :( not near as bad this time. Looking at the bottom of the door where the door trim meets the door I could see water coming from behind the trim and then into the car. I took the door trims off and could see water gets in when the window is up (all cars do) and is supposed to run out the drain holes in the bottom of the door but the water was dripping and splashing up to the back side of the door trim against the sheet of plastic that is supposed to seal against the door with the black mastic (it doesn't) and running straight into the car. I cut some plastic and siliconed them onto each opening on the inside of the door frame and then put the factory piece of plastic on as well (properley this time) as a backup.
So far so good.
May 26, 2012 | Mazda BT50 Cars & Trucks
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerator leaks water from the ceiling of the refrigerator-looks like some sort of duct
When that happens, you will have a door that is not sealing properly. Look around the perimeter of the door especially at the bottom.Once located, you can use a hairdryer to soften the seal then close for 3 hours to allow seal to harden.
Oct 23, 2009 | Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Stainless steel finish on Liebherr fridge
if you have scratched or damaged the surface, you can get a stainless steel foil product to cover your refrigerator from www.applianceart.com. If its not that bad, make sure you are using a stainless steel cleaner after you have washed it with a regular cleaner.
Jul 06, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerators Logo
365 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
