Question about Microwave Ovens
Instructions for kenko kk-613d digital clock - Microwave Ovens
I'm looking for a user manual for a sharp r_269km microwave but no success, I want to set the clock
If you type the following into your browser search box , USER MANUAL FOR SHARP R269km ; when you click on search on the page that appears on the 5th line down you will see 3- Sharp click on it and follow the instructions and if you have a printer you could print your own Manual . Hope this helps you...
Jan 06, 2016 | Sharp Microwave Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Icant figuire out how to set clock on a maison microwav oven sold by aldi stores
Here are instructions on setting the time on the maison microwave sold by Aldi:- 1. Press the "clock" button 2. Press the "Cancel" button 3. Enter the time (at least 3 digits need to be entered) 4. Press the "clock" button again Hope this helps
Sep 12, 2009 | Microwave Ovens
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Setting clock
In most brands, you set the clock by one of these combinations of key presses:
Apr 22, 2008 | Microwave Ovens
Clock Problem
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have the manual, the usual sequenceof clock setting is one of these:
Clock > digits> Clock
Clock > digits> Start
Clear > Clock > digits> Clock
Clear > Clock > digits> Start
Clock > Clear > digits> Clock
Clock > Clear > digits> Start
Otherwise, it may be hard to help beyond this, since it;s been a long time since Toshiba made microwaves.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Microwave Ovens
Microwave Ovens Logo
398 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
