5F-50 ERROR (Fixing unit failure).replace the fixing film unit.i have canon lbp 1000
  • 1894 Answers
SOURCE: Canon Printed LBP 5200 Error Code E000
This error indicates fuser error, its not heating up.
Posted on Aug 10, 2008
ginko
  • 19396 Answers
SOURCE: canon lbp 1000 noir laser
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run thesoftware that you downloaded.
The software installer will tell you when to connect USB.
Some Canon printers are not Vista compatible and cannot work on Vista.
Posted on Dec 07, 2008
  • 122 Answers
SOURCE: Canon Ir2200 Error E007 I have replaced the fixing
take out fixing unit, drive it manually if fixing film do not rotate- apply some mixture of teflon grease and silicon oil on heater element. if fixing film rotating normally,check fixing drive unit.
Posted on Feb 16, 2011
F Victor man
  • 838 Answers
SOURCE: An error message appeared on
Your only option is to buy a new fuser unit.
Posted on May 24, 2011
babaprithi
  • 372 Answers
SOURCE: my canon ir 3045
have u checked the lower pressure roller .sometimes it also causes the damage to fixing film. also check the element as it may not be properly seated .
Posted on Sep 24, 2011
Canon ir2520 showing error code 808. What is the solution?
Code
E808-0000
Description
Fixing drive circuit failure
- The heater does not turn on. - A fixing drive motor failure was detected.
Remedy
- Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the fixing drive motor. - Replace the DC controller PCB. - Replace the power supply PCB.
Jul 05, 2016 | Canon Office Equipment & Supplies
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
Error code E000000
ConditionThe temperature of the fixing unit does not reach thetargeted temperature -10 deg C within 63 sec. afterthe wait sequence is started.CauseThe fixing film unit is faulty. The engine controllerPCB is faulty.
- Replace the engine controller PCB.
http://www.smoothprinterservice.com/
Dec 26, 2012 | Canon LASER SHOT LBP 3300 Printer
Receive this message zhen I start printing: bloc fixation error e000 0000
You can do the following
-Check the connector of the fixing film unit.
If it's ok
Still not solved?
Still nothing happening? Then
Apr 16, 2011 | Canon LASER SHOT LBP-2900 Printer
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
detected.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
I have a canon ir2016i and it reads system error e808
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
If you are not a tech I recomend that you contact one in solving your problem.
Nov 17, 2010 | Canon Office Equipment & Supplies
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Cause: (1) Shorted/broken wired main thermistor
(2) Shorted/broken wired sub thermistor
(3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
(room temperature of 20°C), replace the fixing film unit.
(2) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
(3) With the fixing film unit removed, if there is no continuity
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
Canon ir2016 error E808
detected.
Apr 29, 2008 | Canon PC-940 Black and White Copier
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
