Just replaced pulsator ASM, Mech HSNG ASM Bearing on GE profile washer Model WPGT9150 .When washer goes into spin cycle makes a loud roaring noise.Did not do this in the beginning.
  • gmu1854470 May 27, 2011
    I had a GE repairman come out to service my machine and when he told me that My machine would cost me 1100.00 to fix because it was not under warranty .I got a list of the two parts that he was going to replace and fixed my machine myself for 251.00. I installed the parts just like they came off. The roaring sound was only happening when I put jeans in the machine. Lighter loads worked just fine.The funny thing is that after posting my question on this site the machine quit the roaring sound. By the way I am a woman and have always fixed my own appliances,too cheap to pay the
    outragious labor charges. These two parts were stripped out to begin with. Thank you for your response.
  • 4,323 Answers
Hi
It seems that the stator, rotor assembly and coupling should also be checked, what made you replace the pulsator assembly and mech. bearing assembly is still a question for me however, I believe you either did not replace it correctly or some other parts are causing this issue. You can check the parts by clicking on this link. Hope this helps...please post back for further assistance.
Daniel
Posted on May 25, 2011
  • Daniel Scott
    Daniel Scott May 27, 2011
    You're welcome....post back for further assistance
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Makes a loud roaring sound when it switches to the spin cycle. Can it be fixed? If so, how?
yes it can be fixed but its not worth it. parts alone are over 200.00 dollars. What that noise is is the bearing in the transmission and it will need to be replaced.
Jul 13, 2010 | GE WCCB1030 Top Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
GE Washer WPSR3100W0WW roars like a freight train in spin cycle
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
Jul 03, 2008 | GE Profile WPSR3120WWW
Ge profile WNSB8060BWW VERYYYYYY LOUD
Rear ball bearing broken change half drum or buy new washer ????????????
the super tech
Sep 04, 2017 | GE WNSB8060BWW Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
