I have an oce 2060 that pops a M19506 after it makes 1 copy
3 Suggested Answers
007tech
  • 95 Answers
SOURCE: Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Posted on Mar 27, 2009
SOURCE: Paper jam on my toshiba 2060 model
turn off power:open side: check fuses:check for disconected or broken wires:door alignment:or bent paper guides.
Posted on May 24, 2010
HI I AM GETTING ERROR CODE FOR MY OCE 2060 COPIER
There are many types of error codes, however here is one solution on a specific type found in fixya:
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC. Pretty technical :) kc
Mar 18, 2011 | Office Equipment & Supplies
Toshiba 2060 problem with casette
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / damaged....one of the gears may be also damaged.
Sep 09, 2009 | Toshiba 2060 Copier
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
Oce 3165 Copier makes black copy over text.
that is a very expensive and big machine. as an oce representative i suggest you call it in for service.
Oct 27, 2008 | OCE 3140 Copier
Copies too dark
1-drum needs changing
2-wires needs changing (the cleaning doesn't do anything for it)
3-developper needs changing.
Sep 23, 2008 | Toshiba 2060 Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
50 people viewed this question
jasbo
jasbo
