Question about Photography
I need help fixing an argus showmaster 870. The reels spun for 2 seconds upon starting up and then stopped. Motor seems to be fine does anyone have a picture of what belts are supposed to be where, or an idea of what common problems may be? Thank you.
  • klindahl84 May 25, 2011
    A little rubber disc attached to the motor burns out quite frequently. Donw't know where u can get a replacement. maybe someone e;se on here can help with that.
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
ginko
  • 19396 Answers
SOURCE: argus 1610 driver
Here is the link to argus download.
Select: Download Drivers on first box >> Discontinued Cameras on second box >> DC1610 on last box to the right.
Download and install.
Keep camera unplugged when you begin to install.
Do not forget to vote the solution.
Thanks
Posted on Aug 16, 2008
SOURCE: I have a pioneer RT-909
Hello I had the same issue the take up reel tensions need to be adjusted try this thread tape so that there is no slack hold one of the tension guide reels try the right one first hold it so that it is in the 12 oclock postion this is so that it wont retract to the left which will prevent the motor from stopping or going into the cut off position if it continues to play with you holding it in this position the the tension for the reels need adjusting this can be done by slightly turning the blue adjustment knobs that read PLAY / TU 7 FWD 10 one is for 7 inch reel and the other is for 10 inch reels it's the board at the very top of deck when you take the cover off turn them slightly to the left until problem is gone this is what I did and it worked
Posted on Oct 20, 2008
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
Grubhead
  • 5190 Answers
SOURCE: belt change for Teac a4010sl reel to reel
You can but try! However either make a drawing of how the thing fits together or better still take pictures if you have a digital camera. Then you will know how it fitted together.
Posted on Mar 23, 2009
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
PS3 makes clicking noise, wont read disk...
The only thing to do is get it checked. If you got yours a while after it came out you have a bad lazer. (thing that reads discs) you have 2 get it fixed. Play n trade is who i reccomend. google them. PS: my gamertag is NEROROTT I have all call of duties + a few others like borderlands
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
Help. recently cavitated my 140 hp 1989 mercury outboard motor at high speed.I Removed the lower unit several times but only goes in forward about 5mph. Please help Tx jack
Not really sure what is wrong.Do all the gears work?Does the motor rev properly.Did you change the height of the motor.If the motor etc. are all ok and the motor cavitated at high speed,you may have spun the bush in the propeller hub.The symtoms are,everything works ok but the boat can rev but will have very little forward propulsion.If this is it,the prop needs to come off and taken to be rebushed.The bush stops major damage to the g/box if the prop strikes something.Hope this helps
Sep 07, 2009 | RTO Outboard Motor Bass Fishing Boat Rod...
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
Jul 11, 2009 | Maytag Dependable Care LAT9706
Oster showmaster clipper motor will not run
cord is still burnt out your local grooming tools repair shop will have it or they can put it on for an extra $2
Mar 24, 2009 | Oster Golden A5 2-Speed Universal Motor...
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
Mar 16, 2009 | Sony UVW1800 VCR
I have GE Madellion 870 Washing machine I guess I have motor problem motor stopr after smoke Now Motor spins for few second then stops after 15~ 20 minutes, it will run again for few seconds if my...
Hello ashankhan,
huuum,happy to assist you!
You said,
motor stops after smoke
if my motor burned then why it still runs for few seconds.
The motor is shot and it still works until it heats up, and then it binds up after it over heats!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | Dishwashers
Argus 1610 driver
Thanks
Aug 16, 2008 | Argus DC1510 Digital Camera
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Photography Logo
124 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
