Question about Air Conditioning and Heat for Ford Freestar Limited Minivan
My rear air line as leaks, can I disconnect and just leave front operable?
    Scholar:
  • 88 Answers
No, you can't isolate the rear air from the front air, it's all one system. You would have to fix the leak if you want to keep a/c anywhere in your car.
Good Luck!
Posted on May 25, 2011
Why even with new brake parts in the front and rear on my 2995 Ford f150 2wd truck would front brakes work but not back ? I even put truck on bay lift and hit the brakes and rear just kept spinning.
Bill:
Check your master cylinder. It could be a piece of junk lodged in the fluid port for the rear brake lines, or in the brake line its self. The fact that both rear wheels spin tells me that if it is a clogged line, it is between the two manifolds, (one next to the master cylinder, and the other where the rear brake line splits into two... one for each rear hub. Or it could be that the piston in the master cylinder needs to be replaced. I would disconnect one brake line at one rear wheel and disconnect the rear brake line at the manifold (near the master cylinder)and blow that line out with air pressure. . do not leave the rear brake line connected to the master cylinder as you blow air through the lines as you may damage the master cylinder piston packings. You'll have to bleed the brakes when you are done.
Jan 24, 2016 | Ford Cars & Trucks
Where are suspension airbags located on 1999 ford expedition Eddie Bauer so I can check for leaks?
Front or rear ? Either way rear are on axle just inside leaf springs and the front should be just in from tires going up to inside wheel well .
Nov 18, 2014 | 1999 Ford Expedition
Rear Air Suspension won't air up
take the sensor arm loose and manually operate it, when it is up, it thinks the suspension is low. Spray the bags and hoses with soapy water to find any leaks, dawn dish detergent works well. repair any leaks. If no leaks manifest, take a hose loose and see if you are actually getting air pressure from the air pump. Just because it is running, doesn't mean it is supplying pressure.
Sep 20, 2012 | 2001 Ford Expedition
Coolant leaks from my ford escape I have had it pressure tested and fitted a new cap When parked leaves a puddle of coolant
Always find the source first, The rear water ports are directly behind the rear lower intake bolts and the front ports are directly in front of the front bolts. The rear ports are cast into the lower intake manifold and are dead ends, air can get trapped in that area. In cold weather your thermostat may open slower, resulting in a pressure build up at the rear ports. Any trapped air will compress. Normal coolant system pressure occurs when the glycol is operating temperature. I would try refilling the system and getting the air out,the leak may only occur when the system is full. With a cold engine, open the radiator cap and add 50/50 mix, fill the resevoir to the low mark. Run the engine with the radiator cap off until the thermostat opens, the upper hose will be hot when the stat opens. Turn the car off and refill the radiator to the top. Sqeeze the upper hose to remove any air. fill if necessary. replace cap, run car again until it reaches operating temp. Now with a full system check for leaks. When replacing lost coolant should also have the heat at max temp. Get a good mirror to check for leaks. The outter mating surface of the rear water jacket gasket is flush with the block and the edge of the lower manifold, sometimes you can see where it blew out.
Nov 02, 2011 | 2001 Ford Escape
How to replace a heater core
Heater Core Removal & Installation Front To Remove:
  1. Make sure you have the anti-theft codes for the audio and the navigation system, and then write down the audio presets.
  2. Disconnect the negative cable from the battery.
  3. From under the hood, disconnect the heater valve cable from the heater valve. Turn the heater valve arm to the fully opened position.
  4. When the engine is cool, drain the engine coolant from the radiator.
  5. Disconnect the inlet heater hose and the outlet heater hose from the heater core.
  6. Remove the mounting nut from the heater unit. Take care not to damage or bend the fuel lines, the brake lines, and related parts.
  7. Remove the dashboard.
  8. Remove the evaporator.
  9. Remove the mounting bolts and remove the heater unit. Front heater unit honda-10-00-4128.gif
  10. Remove the self-tapping screws and the clamp.
  11. Carefully pull out the heater core so you don't bend the inlet and outlet pipes.
To Install:
  1. Using care, install the heater core to the heater unit and secure.
  2. Using care, install the heater unit and tighten mounting nuts and bolts to 7 ft-lb (10 Nm).
  3. Install the evaporator.
  4. Install the dashboard.
  5. Connect the inlet heater hose and the outlet heater hose to the heater core.
  6. Connect the heater valve cable to the heater valve.
  7. Refill the cooling system with engine coolant.
  8. Adjust the heater valve cable.
  9. Make sure that there is no coolant leakage.
  10. Make sure that there is no air leakage.
  11. Connect the negative battery cable.
  12. Perform the power window control unit resetting procedure.
  13. Enter the anti-theft codes for the audio and the navigation system, and then enter the audio presets.
Rear To Remove:
NOTE: The rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system) and the rear power transistor (climate control system), the rear air mix control motor (climate control system) , the rear mode control motor and the rear expansion valve can be replaced without removing the rear heater-A/C unit.
  1. Remove the self-tapping screws and the clamp, and then remove the bolts and the rear evaporator lines with the rear expansion valve. If necessary, remove the rear expansion valve. Use a second wrench to hold the other fitting on the valve so the rear evaporator lines won't twist. Leave the first fitting loosely connected so you can use it to hold the valve while you loosen the second fitting.
  2. Remove the rear heater hoses.
  3. If necessary, remove the rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system), the rear power transistor (climate control system), the rear air mix control motor and the rear mode control motor.
  4. Remove the self-tapping screws and the lower housing.
  5. Remove the self-tapping screws, and carefully separate the left upper housing from the right upper housing. Remove the rear heater core.
To Install:
  1. Replace the rear heater core.
  2. Attach the heater hoses.
  3. Make sure no air is leaking from the left upper housing and the right upper housing fitting and from the upper housings and the lower housing fitting.
  4. Before reassembly, make sure that the rear air mix control linkage and door move smoothly without binding.
  5. Before reassembly, make sure that the rear mode control linkage and door move smoothly without binding.
  6. Reassemble the housing.
  7. After reassembly, make sure the rear air mix control motor runs smoothly.
  8. After reassembly, make sure the rear mode control motor runs smoothly.
  9. Refill the cooling system and make sure that there is no coolant leakage.
Oct 16, 2010 | 2005 Honda Pilot
92 regency with abs...rear brake line broke, replaced line and bled line.. no pedal. i bled all the lines, bench bled the master cyl and the abs manifold and still have nothing unless i pump the brakes 3...
Brother, it's just the fact that there is STILL air in your system. Just fill the master cylinder, open the left front line and let it run into a bottle to catch it for a bit until you know for sure all air is gone from that line. Then do the same with the right front. Then the left rear, then right rear. This is gravity bleeding, no pumping required. It's the only way to know for sure that each wheel cylinder and line is free of air. Only let the master cylinder drain down about half way each time the tighten each bleeder. Refill with the drained fluid. Be patient my friend, it takes time to do it right, but it works for me every time. Good day.
Mar 03, 2018 | 1992 Oldsmobile Ninety Eight Regency
I have a busted rear brake line on my 97 Malibu(V6). Stranded outside city limits. In order to ger into town I need to disconnect rear line at the master cyclinder. Is it the front line for the front...
Disconnecting the line won't stop the fluid from leaking out. Your best bet would be to use a pair of Vise-Grips and pinch the line off where it is broken. You'll probably have to pinch it a couple of times to get it to stop leaking or only seep a little and make sur the pliers are as tight as you can get them usung the square flat part of the jaws to cover the line. Hope this helps.
Aug 06, 2010 | 1997 Chevrolet Malibu
02 Trailblazer Rear Blower Doesn't Always Blow.
More then likely the brushes are sticking in the blower motor.
Apr 19, 2017 | 2002 Chevrolet TrailBlazer
'98 Expedition Rear suspension leaking
IFYOU FIND THE AIR BAGS ARE LEAKING (USUALLY IS THE PROBLEM) JUST REPLACE IT. LIFT UP THE REAR REMOVE THE TIRE ,DISCONNECT THE PLASTIC LINE THAT GOES TO THE AIR BAG (push the little grommet pull the plastic hose) DISCONNECT THE WIRE CONNECTOR, AND REMOVE THE CLIP AT THE TOP OF THE AIR BAG (JUST PULL IT) AND REMOVE THE AIR BAG (REVERSE TO INSTALL IT)
(YOU CAN REMOVE THE AIR BAG IN ABOUT 40 MINUTES) EACH SIDE.( on ebay you can find replacement to a regular shocks) or air bags
Oct 19, 2017 | 1998 Ford Expedition
Brake line leak
start from the farthest, right rear, left rear, right front, then left front, take some time in bleeding your left front since it has more air induced during line replacement. good luck!
Oct 20, 2008 | 1990 Acura Legend
Air Conditioning and Heat for Ford Freestar Limited Minivan Logo
56 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
