Question about Makita Garden
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
  • 436 Answers
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
Posted on May 25, 2011
What spare parts should i get
The rotary unit inside the head ,, the small gear set with transfers power through the head
Apr 16, 2014 | Metabo Kn6875 14 Gauge, 5.2 AMP 550 Watt...
Powermate nibbler won't work
Put some air motor lube oil in the air inlet and then hook up air supply. If that doesn't do it then open the motor to see if there is a stuck vane.
Dec 31, 2013 | Powermate Air Nibbler
Does Ace sell nibblers?
Sure. Check out the nibblers available on the Ace site: http://www.acetoolonline.com/Electric-Nibblers-s/1101.htm
Apr 24, 2013 | Cutter Tools
Where can I buy nibblers online?
Try this model from Amazon
http://www.amazon.com/Hitachi-CN16SA-16-Gauge-Nibbler/dp/B00005Q7BR/ref=sr_1_1?s=hi&ie=UTF8&qid=1358332173&sr=1-1&keywords=nibbler
Jan 16, 2013 | Cutter Tools
I don't own an air compressor. Is there another kind of power nibbler that isn't pneumatic?
Yes, there are electrical nibblers that work just as good as the pneumatic ones. of course, there are also handheld manual nibblers too
What is the thickest sheet metal that manual nibblers can effectively cut through?
they should be effective up to about 1/2" thickness. However, on softer metals you can probably go a little thicker, and on harder metals you might have to go a little under 1/2"
What is a nibbler?
A nibbler is a small tool used for cutting sheet metal without distortion.
How do you take it apart?? after taking the 4 screws out, do i have to do something at the tip end?? there is the silver cap like end on it that has 2 depressed spots on it on either side? thanks
Yes, there is an adjustable spanner wrench with a metal *** on each leg. That will spin off counter-clockwise. I have also seen people use a punch to rotate it off, but I would personally use the wrench. If you can provide a model number, I can pull the breakdown or you can go to makita's website, type in your model, and they will have a viewable exploded diagram of your exact tool, making it much easier to plan the disassembly. Let me know how it goes, and don't hesitate to post any questions you might have along the way!
Nov 23, 2010 | Makita 14" Die Grinder
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
Garden Logo
438 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
