Can not change chanels whith remote - Televison & Video
  • 41 Answers
I assume you changed the batteries. Does the other buttons on the remote function. You can test a IR remote my holding up to digital video cam should see red mark in view finder for each button pressed..Also might want to include make model of TV and remote
Posted on May 25, 2011
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
No turn Chanel's manual or with the control
If you have a newer television, the remote control that came with the TV might not change the channel if you are using a set top box. Try using the cable box or satellite remote instead.
Apr 06, 2014 | Televison & Video
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
SHARP LCD TV LED SLEEP AND TV BLINK I and I can't reset whith vol - and chanel down when i plu ac cord someone have an idea ?
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.) ;))))))
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best
Sep 24, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Locoal broadcast on chanel 3 and i have no switch to change output to chanel 4
First does your TV have a remote control? If it does then you have to change the output in there.If you have a VCR try using that if not then you can buy a switch at Radioshack.
Dec 18, 2008 | Logitech Harmony 785 LCD Remote Control
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
