Question about Sony Playstation 3 (PS3) Console
Wheres The Restart Button?
Where is the restart button in the cd tray? And can you scratch the laser that reads the discs by putting the screw driver in the cd tray? Please help me as i want to play my ps3 again, thanks
Hi mi unit dont let mi play any games ,only take me to the green introduccion but no games tried to shut down.
Posted on Aug 19, 2008
Y cd driver wont open
just push the button on cd tray... then the tray will open. if won't read then maybe your cd is damage or the cd drive got in trouble unable to read. try restarting your system.
Dec 22, 2012 | HP Compaq nx9420 Notebook
Tip
XBOX 360 WILL NOT READ DISC SAYS OPEN TRAY
eject the game from the cd console if in the drive make sure your xbox is on warm it up take the disc if it is dirty run under warm water all over the silver side of the disc till dirt and debris gets completely removed after still holding the disc turn off the water and use scott SCOTT brand toilet paper the straight kind and use about four sheets to dry the disc or use a blow dryer, not preffered prefreably scot toilet paper after the disc is dry and warm very dry take your clean index finger and remove the rest of the debris off the disc and when the xbox says open tray let it say close tray close it see if it says read the disc if it says read the disc then it is not your laser or the laser needs to be blowed off with an air gun or compressed air. Get it to say close tray and itll close it self, wait ten seconds turn off the xbox turn it back on and go to my xbox mash play wait for it to read the disc. THE DISC WILL NOT WORK IF IT IS DIRTY I reccomend running it under warm water (let dry on both sides while still holding it properly) use a non scratch cloth to clean the disc preferablly scott toilet paper the smooth kind, after it is dry put the disc in the console if youve tried the disc try a brand new disc it might definately work after it says read if it says play the game then its the disc. If nothing happens like it dont say reading disc then your laser is cracked corrupted, or it has debris on it or is wett. Dont let your laser head get wet because i told you to run it under water make sure the disc is dry and completly free of scratches and smudges. WASH THE DISC WITHOUT SCRATCHING IT. Dont put a wet disc in your x box. Mash the hard drive button down and release mash reset to recycle the xbox green lights. Remove all the cords fromt the xbox wait two weeks or shorter, I waited a month or more before i played my game and it worked after I cleaned it twice one time and a month later i cleaned it without soap and used luke warm water.Remember Open tray, press buttom close tray closing automatically should say read reading reading disc then play if does not read the disc then its your laser. If its your laser and you are sure its your laser do not remove the hardrive or any screws they can tell youve botherd it because that will void your warranty. go to www.xbox.com/support its a pdf file print shipping label follow the steps to repair.
on Jun 13, 2010 | Video Game Consoles & Games
Dvd drive won't read disks
If it used to work but now doesn't and you have changed nothing then the following will help.
You can try a CD Laser cleaning kit, you put a liquid on a disc and put it in the dvd drive.
It will clean the laser, hopefully this will work.
If it still doesnt work its most likely at the end of its life.
Try a Music CD, a DVD, and any other discs, make sure the discs aren't scratched.
DVD drives are extremly cheap these days,
I got a Sony DVD Writers for £18 delivered from Play.com
Its very simple to fit,
Switch off PC
Just take of side of the PC Case
Unscrew the 2 screws on each side of the dvd player, disconnect the wires .
Then fit the new one
The PC will pick it up after a restart and it wont need drivers
Goodluck
Apr 05, 2011 | Compaq Presario 5000 PC Desktop
My xbox will not read the Kintect Adventures game, it tells me to clean the disk or restart console. I've cleaned the disk but it still does not work, how can I restart my console?
To restart either hold xbox guide button (big button with a green x on it) until "turn off console" box comes up and select turn off console, or press the power button on your xbox. There might be a chance that your game disc is severly damaged/scratched and your only option then is to buy a new game or find a service that repairs scratched DVDs . I hope it helps.
Mar 05, 2011 | Video Game Consoles & Games
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Not reading any discs
My xbox is not reading discs. please help.
Jan 13, 2008 | Microsoft Xbox 360 Console
Ps2 will not read disc
Check your disk for scratches fingerprints ect,,
if thats all good step two
try useing a lens cleaner
****(( tip and trick for scratched disks ))****
a crayon rubbed on the disk then wiped off with a lint free cloth
no t-shirts dish towels that will just add more scratches
remember start at the center wipeing out to the edge.
if none of that works you may have a lens problem
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
