Question about Samsung HL-R6167W 61" HDTV
My Samsung HL-R6167WXIXAA won't turn on. I replaced the color wheel, ballest, and lamp. On the front the lamp and stanby/temp lights are both flashing
  • 643 Answers
Have you tried replacing the fans. It might be a thermal sensor tripping. Hope this helps.
Posted on May 25, 2011
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
My Lamp won't ignite. At first my TV was just turning off on its own so I bought a new lamp. Now when I turn it on it just hums in the back and the light doesn't even come on, then it turns...
If the hum came in front of the lamp housing, the fault came from the faulty color wheel. Replace this part and your unit will back to normal operation again.
Oct 07, 2011 | Samsung HL-S4266W 42" HDTV
The lamp will not turn on--replaced and still light--has a flashing red temp light on in front but can not be hot as lamp never comes on. Iss there a way to reset the temp light. thanks Bill
hi if your tv starts for a few seconds and restart again and go
back to stand by chances are that the problem
is what is call the color wheel
Sep 28, 2010 | Samsung DLP HL-P5663W 56" TV
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
Ml-r4667w timer,power,stanby/high temp leds on front panel blink replaced lamp w/original pt
If you replaced the lamp and it illuminates and three blinking leds still appear the you have a bad Color Wheel.
Apr 07, 2010 | Samsung HL-R4667W Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Buzzing sound coming from colorwheel and not spinning as if something was holding it in place. after some reserch I ordered a new color wheel but the same problem so I tried 2 more thinking defictive but...
Sounds more like a lamp ballest. Listen for the sequence of events and please repost.
Upon powerup the fans come on, and the color wheel spins up. Once up to speed the lamp ballest is commanded to arc the bulb,(clicking sound) once lit the power supply just sustains the glow in the lamp.
Apr 01, 2009 | Samsung HL-R5078W 50" HDTV
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W 61" HDTV Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
