Question about Clarion Car Audio & Video
What is the Clarion PN-2165M i wiring conector diagram of 2002 Nissan Sentra GXE?
5 Suggested Answers
firemanb0b
  • 5 Answers
SOURCE: used Clarion AB213R radio/cassette: nowiring diagram
go to ur car audio supplier as they should sell wire harnesses premade so its just a matter of plug in & go! The wires all match.
Posted on May 03, 2009
emissionwiz
  • 76691 Answers
SOURCE: 2002 nissan sentra radio wire
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Posted on Oct 03, 2010
ZJLimited
  • 17970 Answers
SOURCE: Replacing oem car radio/CD (Clarion PN-2165M I)
Posted on May 25, 2011
jturcotte
  • 8531 Answers
SOURCE: I am installing a CD
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Posted on Aug 21, 2011
Why does it lack spark?
Part 1 -How to Test the Ignition COP Coils (Nissan 1.8L)
troubleshootmyvehicle.com > Nissan > 1.8L
Feb 12, 2013 - What Tools Do I Need to Test the COP Coils. ... coils (most commonly known as the COP ignition coils), on your 1.8L Nissan Sentra is pretty easy. ... When one COP ignition coil fails... that cylinder goes 'dead' due to a lack of Spark and is said to be misfiring. .... 2000, 2001, 2002, 2003, 2004, 2005, 2006 ...
Part 2 -How to Troubleshoot a No Start (Nissan 1.8L)
Jan 17, 2013 - Checking for Spark With a Spark Tester. ... Your 1.8L Nissan will either have a distributor-type ignition system or the more modern COP ... A BAD fuel pumpwill cause your 1.8L Nissan Sentra to Crank but Not Start... since the ... Still, the other method that I've used to test for a lack of fuel... is spraying starting ...
2002 Sentra 1.8, no spark, code 0505... - Nissan Sentra Forum ...
www.b15sentra.net > ... > Technical Discussion
Nov 4, 2008 - 15 posts - ‎3 authors
I have never had a problem with the car before (02 Sentra 1.8/auto), so I had no need to post ... Originally Posted by Black B15 ... Join Date: Jun 2005 ... Can you see if the coilpacks are getting spark & work back from there? how many spark plugs do i need ? - Nissan Sentra ...
Mar 19, 2010
Spark Plug Replacement - 2002 GXE 1.8L - Nissan ...
Oct 12, 2009
1.8s starting problems - Nissan Sentra Forum - B15 ...
Jun 23, 2009
No start on 1.8L 02 GXE - Nissan Sentra Forum - B15 ...
Apr 11, 2009
More results from www.b15sentra.net
Jan 01, 2016 | 2005 Nissan Sentra 1.8
Clarion PN.9967H speaker wireing
need wiring diagram for Clarion pn:9967h car radio in 1998 Nissan frontier, right hand drive please
Nov 23, 2013 | Car Audio & Video
2002 Nissan sentra GXE has a code p0350
call nissan give them the vin number thers a recall on the cam and crank sensors do that first
if the recall has been done and ther are no sensor codes find the missing cyl.move the coils around to see if the mis follows if not check batt volts green/white wire good ground at the black/yellow wire after that you need a lab scope to look at the wave pattern of each coil.ther should be 2-4 volt sawtooth pattern all the coils should look abought the same.
Feb 12, 2012 | 2002 Nissan Sentra
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
May 25, 2011 | Clarion Car Audio & Video
2002 Nissan Sentra power won't turn off
look on the back of the intake manifold, there are 2 or 3 ground wires that bolt to the back of the manifold. they ground the park netural switch and body control module if they are not hooked up or are loose it will cause this problem
Feb 20, 2010 | 2002 Nissan Sentra
2002 Nissan Sentra GXE...1.8ltr trying to replace center pipe (exhaust) but not sure how to disconnect it. It looks like a threaded stud on the muffler side and a through bolt and nut on other but it will...
Here is a diagram of the 1.8 exhaust from the service manual, you can obtain a full factory service manual for relatively cheap from Promanuals.net here.
Sep 28, 2009 | 2002 Nissan Sentra
Where can i get free diagrams and manuals for my 02 sentra gxe?
Try the autozone.com website. Go there and register the car information and you'll have access to an online repair manual for the car. Hope this helped and best wishes.
Sep 25, 2009 | 2002 Nissan Sentra
2002 nissan sentra gxe computer
buy a used unit from the junk yard.
Mar 20, 2009 | 2002 Nissan Sentra
2002 NISSAN SENTRA GXE 1.8 POOR IDLE LACKS POWER IDLE FLUCTUATES BETWEEN 1800 TO 1100 RPM
Check for vaccume leaks and also you PCV valve. check the hose too. Visually inspect every vaccume hose you can find. Sounds like a leak .
Oct 30, 2008 | 2002 Nissan Sentra
Car Audio & Video Logo
176 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
