Question about Electrical Supplies
Putting string on spool for trimmer/edger
Hello, I have an old Black and Decker edger/trimmer that when I use it an try to get more line out with bumping it, it will no longer bump out. So what I have to do is take the cover off spool and pull some line out and put cap back on and start trimming. A little later the line breaks (0.65) and I start all over. I am getting frustrated. Help. I think I am winding the cord wrong on the spool and I need to know how to do it right.
4 Suggested Answers
  • 3 Answers
SOURCE: Spool is stuck
Have you tried using vise grips to get it off. Next time put neverseize on it.
Posted on Jul 20, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
cool78259
  • 228 Answers
SOURCE: how do i rewind the
When you pull off the spool it will have arrows embedded,
on the spool to show you which direction to wind it.
good luck!
Posted on Jul 17, 2011
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
Black&decker GH 1000 trimmer. The line breaks when spool is full
Try using a thicker line when using the thinner line it is good only for grass if you should hit fence or concrete it will eat it up and you will be pulling it out every 5 minites or less.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
Jul 01, 2010 | Black & Decker 14" Grass Hog Xp...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
I need to put in new string -- don't know how to install. I need to know what to remove -- do I unscrew something, or do I just stick the string inside the casing?
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
Nov 04, 2009 | Black & Decker 14" Grass Hog Xp...
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Electrical Supplies Logo
587 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
