Question about Dometic Rooftop RV Air Conditioner
Thermostat problem Thanks for replying. It's a 1998 National Tropi-cal motor home. I do not have a good manual on the Duo-Therm thermostat or heater. The picture on the link you sent me looks exactly like the one I have. The part # for the thermostat is 3106463.007(located on the back of the old thermostat). I see that other people have had problems with this same model. I sprayed the push buttons on the unit with contact cleaner and it had no effect. I'm wondering if it is definitely the thermostat or something else. I'm leaning towards the thermostat. I reset all the circuit breakers and checked all the fuses and couldn't find anything wrong. I don't know if their is a fix to the thermostat or if I should just buy another one. I don't know if Dometic has a tech line for this or if they send you to an authorized repair center. What do you think?
  • Dometic Master
  • 6,674 Answers
Try this # Phone: 1-800-544-4881 Ask for tech assistance, if no luck ask for sales rep. Have your Make, model & serial #'s ready for both thermostat you are trying to use & your AC unit. They should be able to tell you if that thermostat will work or not, and if not, they will give you a part # for the proper one. If no luck with that, send an e-mail, with same info & ask same questions to : ( ) or check link below out for same info.
Posted on Aug 16, 2008
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
2009 Luxury by Design 5th wheel. Where can I get an owner's manual?
PDF]RBD Owners Manual (PDF) - Recreation by Design
Also, please review all component manufacturer's owners manuals ... Call our factory and obtain authorization for repairs BEFORE attempting the repair yourself ...... If thefifth wheel is hitched up with the front too high, too much weight will be.
Owner's Manual - Keystone RV
Download the Keystone Owners Manual Revision 4/01/2015 · Download the KeystoneOwners Manual Revision 4/1/14 · Download the Keystone Owners ...
2009 luxury by design 5th wheel rv owners manual - Fixya
5 hours ago - I have been told it is the circuit board. Can I replace this part myself. Thermostat is Duo-Therm by Domestic. In 1998 Aljo RV 5th wheel. Appears ...
Luxury By Design Travel Trailers - PPL Motor Homes
Dec 11, 2015 | RVs
My Duo Therm furnace was working last night and not this morning
I would make sure there is power to the unit before I attempted any repairs. Gas being available will not allow the thermostat or gas valve to operate if there's no power to them
Dec 04, 2013 | Heating & Cooling
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have an old mobile home that has and old duo therm thermostat that is acting up. keeps cycling off for quite awhile and on for not so long. I purchased a honeywell ct-31-a. It only has places for 4...
If you want just heat, connect the red wire to the R terminal, the White wire to the W terminal and the green wire to the G terminal. Confirm that these same wires go to the same terminals on the control in your furnace. If you want both heat and air conditioning, connect a jumper from R to R2. Keep the wires the same as I described and put the yellow wire on the Y terminal.
Feb 01, 2010 | Honeywell Heating & Cooling
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Heater option disappeared
This link may help you identify what you need. What year is your trailer, & AC unit. Have a model # handy ?Have you checked your operators/owners manual ?
Aug 10, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
498 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
