Question about Video Cameras
SVP T718 battery does not sem to be charging. The charge light just constantly flashes with power lead attached. Disconnect lead and you cant turn camera on. The camera is brand new and just arrived in uk from usa.
2 Suggested Answers
SOURCE: Hi. Ive bought an SVP T718 camcorder from USA and
http://shop.ebay.com/i.html?_kw=SVP&_kw=battery
try eBay, I use eBay all the time.. it's great, it's a global world now..
Posted on May 19, 2010
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
I have a 2004 545i BMW. I have a new battery and don't leave the key in the ignition. What is causing my battery to die.
Most likely a short or the Alternator is not properly charging the battery and electrical system. First check the wires that go to the starter and lead from the battery to the Alternator for any breaks or possible shorts that are allowing the Positive wires to ground. If those are good, disconnect the battery positive wire and connect the jumper cable directly to the positive cable and jump the vehicle. Once it is running disconnect the jumper cable and test the voltage on the positive wire to see what the alternator is sending as a charge to the battery. Anything less than 12 v is an obvious problem and I believe it should charge at 14v but you would have to check the book on that. Your other option would be to remove the alternator and have it tested at one of the Auto parts stores that offer to do that, Auto Zone and Advance Auto come to mind. If there are no shorts and the Alternator is good then that leaves the Alarm system and interior lights as being the problem and you will have to isolate those areas for shorts or constant connections. You may have accidentally set your interior lights to constant on which would bypass the timer system if you have one. Check the dash brightness control knob to make sure it isn't turned all the way to one side or the other. This position typically sets the interior lights to constant on.
Jan 17, 2011 | 2006 BMW 750Li
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
2005 mazda six. car working fine one day next day not starting and charging system warning light flashing. started with jumper leads. next day not starting again. battery replaced now security indicatore...
When ever a batter this new goes bad, it is either because it is not being charged, because there is something wrong with the charging system, or there is a constant drain even when the key is off.
To check the latter, with everything off, you remove a battery cable and see if the is any glow from a test light between the post and the cable. If there is, then you have something on that should not be, all the time. Then you pull fuses and disconnect things until it goes off.
To check if the charging system is not working, the easiest way it is to borrow a battery to get it started, (don't jump start a car if you can avoid it, because you can ruin an alternator when it starts, because it will kill itself trying to charge up that bad battery.) With the lights on, rev up the engine. They should get slightly brighter. Of with a volt meter, see it go from 12.5 to 13.5 volts, or so. If it does not go up, then your battery is all that was powering the car, and it won't last long like that.
Jan 20, 2010 | 2003 Mazda Mazda6
Cant get my svp t 100 battery to charge
I ran into a similar problem. After taking my T-100 out of the box, I left it on charge overnight. The specs on this camcorder state it takes 4 hours to fully charge, so it should have been sufficient, however, when I turned the camera on, my battery level on showed two out of three power bars. I checked at the SVP website (www.svpcam.com) and found there was a firmware upgrade available for the battery meter. You can find instructions and a link to the firmware file here: (http://www.svp-tech.com/Instruction%20of%20updating%20firmware.htm)
They don't do a fantastic job of explaining what the patch fixes, but I found the above referenced link titled T-100 battery firmware, and it redirected me to the page for instructions. I followed the instructions (again, just to reiterate - the instructions display as "Instruction (SD card or MMC card)" not "Battery Firmware for T-100" (like it should). After formating my SD card, downloading the file to the SD card, and holding buttons, etc., my battery level indicator shows that I have a full charge.
I've seen dozens of inquiries along the lines of charging the battery and there were no responses. I hope this resolves your problem so you can enjoy such a neat little gadget. We absolutely love ours. Best of luck.
Sep 03, 2009 | Video Cameras
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
Video Cameras Logo
89 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
