Question about Microsoft LifeChat Stereo Headset with Noise-Canceling Microphone
Crackly Headset My headphones are putting out a crackly noise, and a soft static is produced when I attempt to speak through the microphone. I believe it may be a disconnected wire. If so, how would I open up the headset to check? And if not, what could be wrong?
  • Anonymous Sep 29, 2008
    really annoying cracking static sound
Mate, im having the same Problem i have no idea what to do!
When the Red light is on, it doesnt crackle, but when the Red light is on.. i cant use it as a Microphone.
But when i turn the red Light off.. there seems to be a crackly noise everytime i speak!!
I did manage to fix it for like a day.. i just pushed all the wires and it seemed to work. but hasnt for over a month now..
Posted on Oct 01, 2008
I had same issues but hadnt bothered install the driver cd that came with headset I had let XP find it.. so just installed the CD and had to upgrade to latest windows messenger, then replug ur headset in or pull out and reinsert usb and all should be fine :)
Posted on Feb 15, 2009
Sound from headphones on computer terrible
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You will need to open up your computer to check the back of the input headphones plug look for dusty and bad soldering or loose connections. b> Computer Headphone Jack Has Fuzzy Noise b> When building a computer system, making headphone and microphone jacks are one area where computer manufacturers use the lowest-cost parts. When it comes to computer audio, no perceivable difference in sound quality exists between that of ordinary parts and higher quality ones. Very low-quality parts, or parts that are installed with sub-par wiring, however, can lead to fuzzy sounds and static on headphones.
Symptoms and Component Isolation Start the diagnosis by using different headphones in the jack. If the fuzzy noise or static problem persists over multiple headphones, even if it doesn't happen with all of them, it's probably within the jack on the computer. This is also probably the case if the static increases when you do other things on the computer, like dragging windows around on screen with your mouse, then stops when you stop dragging windows. Causes b> The leading cause of headphone jack static is electromagnetic interference from other components in the computer's case. When electrical devices draw current, they also generate a magnetic field. Overlapping magnetic fields cause static. To combat this effect, the manufacturer provides for the components on motherboards to be grounded - the wiring from the microphone jack will have an extra lead that goes directly to a grounding agent. When your computer headphone jack has a fuzzy sound, or static, the ultimate cause is usually bad grounding on the wiring that the jack plugs into. Rewiring The Jack b> If you're comfortable with a soldering iron, and know enough about electronics and wiring, you can remove the wire to your microphone jack and put in one with heavier shielding, or a better ground. If you're not comfortable with this, a computer repair shop may be willing to tackle this for you; the actual cost in labor is about an hour to an hour and a half of labor time. It may be less if the shop technician is familiar with this sort of repair, as opposed to only knowing how to swap cards on the motherboard. Using Different Ports for Audio Cheaper alternatives exist than rewiring the headphone jack on your motherboard. One of them is to put in a dedicated sound card - which will cost $15 or so, and you may have a compatible one from an old computer that can be scavenged. This will require researching the make and manufacturer of the card to download compatible drivers off the internet, and then installing them on your computer. If you have an unused USB port, the easiest solution is a pair of USB headphones. This has the advantage of working with future hardware as well.
How to reduce static in my audio http://www.miracletutorials.com/how-to-reduce-static-in-audio/
Feb 27, 2013 | Computers & Internet
The Mic will record, but when i plug in my headphones into the the mic in the front...it still continues to record when speaking, singing into it...but i cant hear the music (instrumental) in the...
This could be due to the output volume and monitor mix are turned too low. You can fix this by adjusting the input gain levels in the ASIO settings menu.
Apr 07, 2011 | M-Audio Producer USB Microphone with...
My Dell Inspiron 545 computer makes a constant low hum. When I record audio (my career), it picks up on the mic. What can I do?
Get a much longer USB cable and distance yourself and the mic from the computer.
You could also try putting some soft services near the computer so that the noise doesn't travel.
Mar 20, 2011 | M-Audio Producer USB Microphone with...
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Used to have this
a microphone and a speaker work off the same principles. there is a magnet and a coil. when you speak,the air makes the speaker cone move and the coil produces a signal because it is moving across a magnetic field. when you apply a alternating voltage to the coil,it moves in opposite direction to the magnet because likes repel and opposites attract. if you apply dc to a speaker it will stay in or out depending on polarity.a bass guitars lowest not is about 50hz or cycles per second.the signal is going plus minus 50 times per second and that is why a speaker moves.because of the size of large cones,they can not move so fast,that is why woofers are big to move lots of air,and tweeters are 1 inch or so,because the range is 20khz or 20000 cycles per second.beacuse microphones have to be very sensitive,the voice coil and structure are extremely small and light.a microphone will produce sound with a signal applied,but burn out with very little power.even a clock radio will blow it out.
Jun 12, 2009 | Microsoft LifeChat Stereo Headset with...
Microphone has undelying static and hiss
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. Best to use headphones when recording.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 06, 2008 | Microsoft LifeCam VX-3000 Web Camera
Zoom H2 static noise
hello you need to change the wire phone colud be broken, o resolder where they hook up thats why you are getting that noise....saludos
Oct 21, 2008 | Audio Players & Recorders
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Open Questions:
Microsoft LifeChat Stereo Headset with Noise-Canceling Microphone Logo
556 people viewed this question
Top Microsoft Radio Communications Experts
Adrian W
Adrian W
Level 1 Expert
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
