Question about GE JVM1860 Microwave Oven
My jvm 1861 oven does not power on at all. how do i disassemble the control panel to replace the fuse
  • GE Master
  • 9,085 Answers
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
The fuse should be accessible after removing only the grille, with no need to remove the controller.
According to a similar model's service manual:
"The fuse is located on the upper duct mounted to the Noise filter.
1. Disconnect power and remove grille.
2. Replace the fuse."
You can find handy exploded views and order parts by model number
here.
Posted on May 26, 2011
I have a GE Over the range Microwave oven, Model JVM 1540DN. It will not stop running, doesn't seem to be heating up and turntable doesn't turn. When I shut door, it turns on and won't go off. Any...
Probably a bad door switch or mount.
See
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 07, 2010 | GE Microwave Ovens
I am realtor. Just sold home with built-in over the range GE Spacemaker 2.0 microwave oven (JVM 2070). The three buttons on lower right hand side (vent, boost, light) are missing. You have to stick...
Yes. You can find handy exploded views and order parts by model number here.
To aid in disassembly, the service manual is HTML clipboard here.
Sep 07, 2010 | GE Profile Spacemaker Over-the-Range...
How do I get to the fuse for replacement?
remove panel that's over the door (screws on top). next, remove control panel by unscrewing usually 1 screw on top of panel. finally, lift panel upward; then pull foward. of course, unplug power cord before disassembly. fuse should be 20amp 3ab20 ceramic snap-in fuse and is located inside up high near cooling fan. fuse can be obtained at radio shack. keep in mind fuses fail for a reason.
Aug 23, 2010 | GE JVM1870 Microwave Oven
Ge model jvm 140 complete loss of power. all lights are out. there is power to receptale
Not an easy situation when it's mounted above the range,it will have to be taken down,remove the outer case and look for any and all fuses, it sounds like you have a blown fuse or if they all look good you may have a bad power supply or bad control board.
If it isn't the fuse I am not sure if it would be worth the investment to get it repaired, you may be better off to replace the whole unit?
Good Luck !
Apr 23, 2010 | Microwave Ovens
I have a jvm 1653 microwave that just quit. I
I would suspect a blown fuse or the TCO (thermal cutout) / themrostatr on the magnetron of on top of the oven cavity.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Jan 30, 2010 | GE Microwave Ovens
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave part
GE JVM 1660 Microwave. Everything is working fine except it will not heat.
Apr 13, 2008 | GE JVM1660 Microwave Oven
Unit not powering up
There is a fuse located behind the control panel.
If that is good, or replacing it does not fix it, you may have a problem with the control panel, which we repair nationwide for $39.95.
We have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Oct 12, 2007 | Sharp R-1870 Convection/Microwave Oven
Microwave has no power.
Since you have power going into the cord, there are three things to check next, with reference numbers from the exploded view found via the link below: REF # 1626 internal fuse REF # 1430 magnetorn thermostat REF # 1121 flame sensor If any of these parts is open, you will have a "no power" / "dead" condition. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 11, 2007 | GE JVM1660 Microwave Oven
GE JVM1860 Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
