Question about Briggs & Stratton Garden
Briggs and stratton 16.5 hp model 310777-0112-e1 will not stay running. starts for a few seconds at best then dies. replaced fuel filter and spark plug with no improvement.
  • 18 Answers
SOURCE: 18 HP Briggs and Stratton OHV Model 31M777 runs rough
Have you checked the choke? Sounds like it might be stuck closed or partly closed.
Posted on Jun 22, 2009
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
  • 80 Answers
SOURCE: Starts but won't stay running
It sounds like you are getting a vapor lock.
Try getting the fuel line and fuel fillter away from the motors heat.This will cause the fuel to boil and give you trouble. Check all your electrical connections for that clicking problem. Make sure everything is clean and tight. Check your spark plug gap.
John
Posted on Sep 28, 2009
SOURCE: Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
Posted on Nov 28, 2009
  • 15 Answers
SOURCE: MTD Model #13506756336 Ser #1A115C50008 16 HP
Possible faulty "operator presence relay" #1
Posted on Apr 19, 2010
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
I have cleaned the carb for 20 hp briggs and stratton engine and still cant get it to run
Not sure what you mean by 'run'. Engine needs fuel, spark and air to run. And the fuel has to be in an exact proportion to the air.
Air is easy, temporarily remove the air filter.
Fuel is tougher - I would recommend you get starting fluid and spray down the carb (now that you have air cleaner removed).
Spark is toughest. There are some tools that can verify there is a spark and there are some more expensive tools to verify the strength of the spark.
If you have spark, the engine should at least fire up. If the engine dies a few seconds later, you don't have fuel flow. Carburetor is still not working.
Is the carburetor fuel bowl full of gasoline? If not, check filter and needle and seat.
If you have fuel, make sure the jets are clean. The carb sucks fuel out of the bowl via jets. This empties into the carb's venturi (the throat). Take spray cleaner and spray down the little passage in the throat (not into the engine) and you should see the cleaner spray into the fuel bowl. If not, try spraying through the jets and watch the spray come into the venturi.
When air enters the engine, it causes a vacuum that sucks the fuel out. This is physics. The only way it doesn't work is if there is a clog in the system.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a sears lawn tractor with a 25 hp ohv briggs and stratton engine. The problem is that it runs very rough, black smoke and has no power when the deck is engaged. I have replaced the air filter,...
So have you actually checked spark to both plugs? If so then inspect valves to be sure valves are operating. Sounds like running on one cylinder. A quick check would be to unplug one spark plug at a time. You may find if you remove the dead plugh wire, there is no change. If you unplug the running cylinder it probably won't start. Sometimes the compression release mechanisms can come apart or come loose. Download your manual for you engine model at www.briggsandstratton.com
Aug 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
225 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
