Question about Sharp Heating & Cooling
I have a Sharp CVP12LX Portable Air Conditioner and i runs for 10 mins then compressor shuts down fans still blows but now blows warm air if i reset the plug it will work for 10 mins then does it all over again the unit will cool but it takes almost 10 mins to kick in if it feels like it any help would be welcomed
SOURCE: No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Posted on Jun 29, 2008
  • 230 Answers
SOURCE: poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Posted on Jul 03, 2008
SOURCE: air conditioner
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
Posted on Sep 24, 2008
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Posted on Jul 06, 2009
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
Portable air conditioner compressor turning off and on
If the air conditioner is equipped with a low pressure switch it could be low on refrigerant, there is also the chance a poorly connected thermistor is sensing frost (erroneously) and shutting the compressor off. including a model and serial number helps to narrow down the potential causes for the cycling compressor.
Oct 27, 2017 | Heating & Cooling
My conditioner Sharp CV-P12LX shuts down after 10 min of operation. A noise is heard in the plug reset switch as well
If you have to reset the plug then its pulling to many amps. If you don't know what else is connected to that particular line (in your breaker box) you might consider using another outlet. Increasing amps. of breaker may not be advisable without consulting an electrician.
Jan 24, 2011 | Sharp CV-P09LX Portable Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Poetable AC compressor licks in for 10 min
Jul 03, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
46 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
