I have a 1BTG585N wireless router and my Nokia phone E66 needs the pre Shared Key setting. How do I obtain this please
5 Suggested Answers
serra_baby
  • 144 Answers
SOURCE: Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
Posted on May 30, 2008
Geekman
  • 32281 Answers
SOURCE: No Wireless Connectivity
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from other wireless routers and access points in your area.
Posted on Oct 09, 2009
SOURCE: want to know the pre shared key
how do you go to the configuration page of my router?
Posted on Jan 04, 2010
SOURCE: i need the pre shared key to access internet on my
You can find it in router configuration page. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then note down the WEP key it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 22, 2010
Forgotten pre-shared key for D-Link Router
I thought there was a check box in this model that enabled you to see the password/key. If not then you may have to do a factory reset and set-up everything from scratch. Cannot remember if this model has a guest mode, but if the device you are connecting is not critical, TV, BlueRay, Roku etc, then enable the guest mode without a password to connect. These devices will NOT connect to other things on the network, but if they only need internet access it may be OK.
Dec 30, 2011 | D-Link DIR-615 Router
Hi, when i try to connect through ma mobile wireless, it gives me a note to type a pre-shared key,,,i don know wt is it, and how to get!!!? would u help me plz
The pre-shared key is for data encryption over wireless. It is set on the router/access point by the Admin/owner. If that's not you, you'll need to ask somebody for it.
http://en.wikipedia.org/wiki/Pre-shared_key
Jun 27, 2011 | Computers & Internet
Im trying to use my mobile phone through wifi on my home broad band but says i need a pre shared key number how do i find that number
The pre-shared key is nothing but the password you use to connect to your home network. Just type in the password and connect
Jun 14, 2011 | NetGear WGR614 Wireless Router
How do i put a password on my connection
please write your address box the below link,
http://192.168.1.1
Then, it opens your user interface of the modem.
You can manage your modem now.
Find your Wifi Protected Access (WPA) and Pre Shared Key (PSK)
Choose one of encryption techniques. I use TKIP.
Wireless Protected Access with a Pre-Shared Key: The key is a password, in the form of a word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols. Each client that connects to the network must use the same key (Pre-Shared Key).
Put a password to your connection settings and save it.
I hope this will be helpful.
May 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Need gateway adress to my nokia E66 to authorise it to my wireless router...but how do i get this?
change ur wireless router settings to dhcp from static or just put the gateway address ie the default address of ur wrouter that u use for making any changes to the router
Jan 10, 2010 | Nokia E66 Smartphone
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
We do not have a secure connection to our wireless rotor
You could change and configure your router through its web interface. To access it, use http://192.168.1.1 on Internet Explorer, and enter 'admin' for the password.
  • Go to Wireless LAN Security tab.
  • Select WPA-PSK on Network Authentication.
  • Enter a password that you want for your wireless network on WPA Pre-Shared Key (minimum characters is 8).
  • Set Data Encryption to TKIP.
  • Apply settings.
You should now reconnect your wireless computers to your network and enter the WPA Pre-Shared Key.
Oct 12, 2009 | Airlink 802.11G Wireless 4-Port Router...
MSI
The Pre-shared key is used to setup encryption on wireless routers.
The latest strongest encryption methods used is Wi-Fi Protected Access (WPA and WPA2).
The wireless router is configured with WAP or WAP2, and the computer's wireless card is configured with the router's WAP or WAP2 encryption. The wireless router will now allow communication with the computer's wireless card, data transmitted between the router and computer is encrypted and therefore protected from unauthorized access.
Sep 08, 2009 | MSI Wireless-G RG54G3 Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect dlink to n95
Hello...the pre-shared key is also known as the network key, and you can find it within your router settings.
Open a web browser, and login to your router by typing http://192.168.0.1 into the address bar.
You are prompted for a username and password. Enter username: admin and leave the password blank, or enter your password if you have set one.
Go to Home >Wireless. You should see your pre-shared key, or network key there.
Hope this helps you, but please come back to Fixya if this does not work or you need further help.
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
