Question about Toro Garden
HI THERE HAVE A POWER DEVIL GARDEN LAWNMOWER MODEL NO SL1P64F STARTS UP WITH PULL CORD BUT KEEPS CUTTING OUT. HAVE CHANGED SPARK PLUG & HT LEAD
  • 1,338 Answers
Ther is a real good chance yo have water in the gas, you will need to drain gas tank and the carb.i would do a carb kit (take your time, i bent the governor on my mower) about 10$... use marine gas, it has no alcohol in it (bad news for small engines ! ) makes the gaskets in the car last longer.. hope this was of some help.. check out my other answers , for more kool tricks.. and please rate me with a yes it was of help.. its the gas that keeps me going and answering your guys Q's .. jay your local pool pump motor repair guy in longwood florida
Posted on May 25, 2011
    Guru:
  • 479 Answers
The chances are that there is a problem with fuel delivery, maybe in the float bowl or the fuel filter is blocked.
Have a look at these tips:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Posted on May 26, 2011
Toro lawnmower model no. 20065. Did what you said. Can't get cord to pull or flywheel to turn. Plastic part is okay.
Hey June, remove the spark plug... see if it will turn over then,,,
If fuel sprays out of the spark plug hole.. you MUST change the oil, air filter, spark plug and have the carburetor cleaned and adjusted BEFORE you try to start it again!@!
IF the engine will not turn over with the spark plug removed... its time for a trip to a professional small engine guy... sorry...
Aug 21, 2017 | Toro Garden
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Will not start, no spark
try this test. take off the spark plug cap ( they unscrew ) snip a small piece off the ht lead ( as the metal inside will be chewed from the thread of the cap ) with a new cut hold the lead against any metal near it ( the cylinder head etc ) and pull it over. you should see a spark from the lead ? if you do you can replace the cap ( it will have new wire to screw into now ) and try fro spark at plug ( no spark new plug needed ) ..if you get no spark from the ht lead unscrew it from the coil and try a new lead
Apr 30, 2015 | Poulan Pro PP133 17" Gas Trimmer
New unused Craftsman Push Mower will not start
May be bad battery ? Have you try another battery ?
Apr 11, 2013 | Garden
I have a 2007 keeway f-act 50. it has developed a proble, its starts fine but when i pull the accelorator the bike goes up to around 7000 rpm and the engine starts to cut out. i have checked the HT lead...
I will recomend you to clean the carburetor and change the spark plug. If the spark plug is bad it might get problems to set fire to the gas. so change it and you might get your motorcycle working again. Good Luck.
Jun 08, 2011 | 2007 Aprilia SR 50 R Factory
Mantis-20 will not start - have tried new fuel?
Hi, chances are the old fuel has gone bad and caused the spark plug to get muck on it, i would go out and buy a new spark plug then leave the plug out but fitted to the ht lead, then rest the plug on a metal part of the engine then try stating it and make sure you have a good strong spark between the gap in the plug, if you have a good spark then take the plug out the ht lead but also leave it out the engine, then keep pulling the starter for about 20 to 30 seconds to ensure you have only the new fuel coming through into the combustion chamber, you should be able to smell the fuel after few seconds, then put the spark plug back in and try starting it, you should find it will now start.
let me know how you get on or if you need further assistance ok
Mar 07, 2011 | Mantis 2-Cycle Tiller
Engine has no spark. 3HP Briggs and Stratton +
If you get a shock from the HT lead then you do have spark!!
Connect spark plug with it removed and shorted to see if there is spark, if not use screw driver to hold away from steel (1/4") with end inserted in HT lead,If good spark / faulty spark plug.
Check for
Spark
Fuel to spark plug
No air leaks.
Mar 16, 2010 | Briggs & Stratton 1928 1 amp Transfer...
Hard to start, new racher455
1) Check plug & gap if that doesn't work try new plug. 2) Try cleaning air filter 3) Clean out main jet 4) Test petrol filter inside tank if dirty fit new one 5) Take plug out & fit inside HT lead & put to head of engine & see if you can see a spark when you pull the cord
Jan 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Fiat Sicentio 1.1 (02 plate) problem after changing spark plugs
check spark plug gaps are set correctly and that leads are in correct order if you took all leads off at same time its easy to mess up just one or two
Nov 08, 2008 | 2007 Fiat X1/9
Garden Logo
309 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
