Question about KitchenAid Architect KEBS207S Electric Double Oven
The top oven does not heat up. The convection fan is working fine.
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 112 Answers
    SOURCE: OVEN WON'T HEAT
    You have a thermal cutout, usually, behind the back access panel, which is known to cause this problem. It may or may not be resettable but I recommend replacement either way.
    Posted on Nov 08, 2008
    SOURCE: kitchenaid KEBC177 electric convection oven will not heat
    This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
    The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
    The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
    This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
    For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
    Posted on Dec 09, 2008
    SOURCE: Oven will not heat up on bake broil or convection cook.
    I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
    Posted on Apr 09, 2009
    Noise when oven running and stops when oven stops
    Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
    Dec 02, 2013 | Thermador SC272T Electric Double Oven
    Oven was heating and we got HEAVY smoke....
    Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
    Jan 25, 2010 | Ovens
    Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
    whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
    Dec 17, 2009 | Baumatic Ovens
    Neff u1421 bottom oven: Either fan works but no
    You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
    Please rate my solution.
    Thanks.
    Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
    Elements in convection oven won't heat
    DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
    http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
    It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
    P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
    Mar 04, 2009 | GE Ovens
    Bosch convection double oven,ovens won't heat,only broilers work
    If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
    Plz rate my\solution.
    Thanks.
    Dec 17, 2008 | Bosch Ovens
    Oven is not heating...the convection fan blows, but no heat
    If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
    Plz rate this solution.
    thanks.
    Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
    Re:Electric Convection oven does not heat up. Convection fan works, light works.
    It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
    Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
    Fan assist wont heat oven
    the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
    Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
    KitchenAid Architect KEBS207S Electric Double Oven Logo
    20 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
