Question about Nextar MA923T (1GB) MP3 Player
Error 41 My mp3 player displays on the screen a unreadable menu, and later it displays in the screen Error:41 what can i do.
  • Nector Akhilo Aug 16, 2008
    A solution i tried is : erase all information from the device ,take the battery out....make sure the item is not connected to the network in the following 10 minutes, because its going to loose the reserve power,,, then connect the device without a battery on, reformat the device, put it on a default mode, and run the antivirus into the device....but if it doesnt work, the best solution will be the lawyer and the lawsuit.. cause its making people loose there money in big amounts,because its not expensive, and not only one person buys this stufff...imagine that the error 41 is in a million of devices, it will make nextar corp.. more wealthy.....
  • Anonymous Apr 19, 2009
    I have a LAZER mp3 player 512 MG.. When I want to play any song ,it plays it for about 5 sec then the screen seems so unclear, then it says Error ( )41. I have tried to format it so many times and I also made my antivirus NOD32 to see it .. but no change .. and when I bought it, there wasn't any CD with it .. So please anyone knows how to fix this?
Display screen cracked
go to home and click on settings then scroll and you will find it
Apr 08, 2009 | SanDisk Sansa Clip MP3 Player
Tip
How to Change the Display Settings for your MP3 Player |
You can personalize your music player by changing the appearance of your background. This will also help you to read the screen while making the icons easier to see.Follow the instructions below to change the display settings on the device.
Instructions:
Things You'll Need:Owner's manual,mp3 player
1.Turn on your MP3 player and use your keypad to select "Setup." Push the center button on your keypad to highlight "Display" on the Setup menu.
2.Use the keypad to scroll though the languages on the Display Menu. Push the center button on your keypad to choose one.
3.Scroll down the menu to the "Brightness" options. Press the right arrow on your keypad to increase the screen's brightness, or press the left arrow to dim the screen.
4.Scroll down to the "Wallpaper" selection on your Display Menu. Use the arrows on your keypad to scroll through the different backgrounds for your MP3 player.
5.Change the icons on your MP3 player. Scroll down to "Appearance." Use the arrows on your keypad to scroll through the different icon choices.
Tips & Warnings:
Make your own background by downloading photos from your computer.Dim the brightness in low light situations to save battery power.
on Feb 10, 2011 | Audio Players & Recorders
Anko directory error when plugging into my computer
Microsoft error management for error 47 says
When the "safely remove hardware" icon is in the status bar (the by time) disconnet the mp3 player. After a few seconds connect it again. Then reboot the computer system. You will then be able to see the contents of the mp3 payer.
I tried and it works. Also it means the player could be removed without clicking on"safely remove hardware".
Jun 04, 2008 | American Anko MP-2GD MP3 Player
Displays error 41
Im having the same problem :| just with a different mp3
May 27, 2008 | Nextar MA933A MP3 Player
Error 41
do you have cd with it. Maybe the solution on your cd. Look what the content on your cd?Maybe like format tool?
Apr 19, 2008 | Audio Players & Recorders
Software Installation Disc Problem for RCA 512mb ModelTH1100A
when iam connecting rca emusic1 digital player to the computer having windows xp sp2, the computer freezes and after some time windows displays error report like this"windows - delayed write failed" can u suggest me how to open the rca through usb..
Dec 25, 2007 | RCA eMusic MP3 Player
A problem with my mp3 player
format the drive and use "safely remove hardware" function to diconnect it from the usb from now on
Dec 15, 2007 | Audio Players & Recorders
Error 41
probably the wrong format
Oct 16, 2007 | Coby MP-C7085 MP3 Player
Sony NW-E505 MP3 Format Error
Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
Gogata
Oct 11, 2007 | Sony NW-E505 MP3 Player
"Format Error" after format with windows explorer (XP)
Hello, please check this link: http://support.sony-europe.com/DNA/WM/NW... If you need more info please advice. Arpi
Feb 01, 2007 | Sony NW-E405 MP3 Player
Nextar MA923T (1GB) MP3 Player Logo
108 people viewed this question
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
