Question about Verbatim 320GB USB Portable Hard Drive
How do I use this to backup? - Verbatim 320GB USB Portable Hard Drive
  • Verbatim Master
  • 27,725 Answers
Depending on your operating system this may vary click start control panel you should see system security tab in that back up then windows will ask for a back up DESTINATION location you can select either dvd or another device in windows7or all programs accessories system tools you should see back up in xp after the back up finishes windows will tell you your computer back up was successfull also you could right click on the back up file select properties this will tell you how many GB were used
click start control panel system security tab in that back up my computer in windows7or click start all programs accessories system tools you should see back up in xp
hope this helps
Posted on May 25, 2011
Remove unwanted backups
Format Hard drive and them backup only 1 time. In the future, create an additional backup and then after that delete the oldest backup. I backup my system about every month.
Mar 06, 2014 | NTI Backup Now EZ
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    How do I manage and delete files on the iomega to make room for new backups?
    when you plug in the drive it should mount it self and an external drive you can get to it by clicking on my computer and usually it will be labeled removable disk.
    Mar 02, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
    I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
    You have a varity of option to do your backup depending on the type of backup you want to do.
    1 Documents and folders
    To backup your document and folders you can just copy the Documents and folders to the external drive.
    You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
    2 System backup of your system.
    You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
    Windows Back for Windows 7.
    Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
    This will save your files to the external drive you added to your system.
    Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
    T3 sync with PC- Windows XP
    Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
    Sep 14, 2008 | Palm Tungsten T3 Handheld
    Error copying file or folder
    One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
    All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
    Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
    In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
    In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
    When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
    If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
    Feb 11, 2008 | Buffalo Technology 250GB USB SATA 2.0 HD...
    Restoring files from the database
    I suggest you use the Enterprise manager (gui tool to manage SQL).
    Restoring a single table is not an option.
    You can however restore a file or filegroup.
    Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
    Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
    You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
    oh yea..... did I say backup?
    well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
    but dont overwrite that backup
    Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
    Verbatim  320GB USB Portable Hard Drive Logo
    150 people viewed this question
    Top Verbatim Computers & Internet Experts
    Martin Murray
    Arora Singh
    Arora Singh
    Computer Links
    Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
