Fault f08 - Washing Machines
  • 17,970 Answers
The heating element is gone open circuit. Replace element.
Error F08 means that the heater relay cannot be activated. Check connections on:
- pressure switch.
- heater element.
- control module.
If you still cannot get it to work, then you are probably going to have to call an technician service.
Hope this helps.
Posted on May 25, 2011
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
Posted on Jan 16, 2010
Bosch WTE86303 Electric Dryer fault F08
I found this elsewhere on the net: "F08 means the door was opened mid cycle."
Nov 03, 2014 | Bosch WTE86300 Electric Dryer
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Came up on red service light with fault F08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Dec 07, 2010 | Whirlpool Washing Machines
Hope this helps.
Jan 16, 2010 | Washing Machines
Hotpoint ultima WT965A fault code F08 what do i need to do to fix it please. wachine is full of water and i cant select any cycle to empty it.
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Jan 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
F08 keeps flashing
probably heater relay cannot be actived, you will need an engineer.
Nov 18, 2008 | Indesit WA 125 Front Load Washer
Washing Machines Logo
560 people viewed this question
Top Washing Machines Experts
