Question about Kodak EasyShare CX7330 Digital Camera
Poor quality pictures
All pictures come up to be trashed on screen and are very dark. Outside pictures clouds and sky assume a pink colour.
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Posted on Oct 10, 2008
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
Plasma screen problems
Likely if picture comes on and is very dark like a black swirling cloud or similar you could have a bad PDP or Plasma Display Panel.
What can happen is the panel is a sealed unit with an inert gas inside---if there is even a tiny rupture inside the panel the gas goes and bingo====very dark screen that is almost impossible to see the picture on.
If this is the case it is fatal as Panel is more than a new set discounting major labor to replace it.
Mar 14, 2012 | Philips 42PF9630A 42 in. Plasma Television
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Toshiba TV colours wrong pink sky, blue clouds and green people??
Inside your TV there is like a loop of insulated wirings the loop around the screen. This is to demagnetized the tube. There is a varistor which looks like a thick coin with two leads on it, or sometimes it looks like a flat ceramic capacitor that control this loop of wire. When you first turn on your TV current goes through the loop of wires to demagnetize the TV then the varistor shuts off. Sometimes this varistor fails, causing smeard colors. You can also demagnetize the screen without opening the TV. Using a hand held demagnetizer. It can be purchased at some electronic parts store.
Jun 28, 2009 | Televison & Video
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Is the TV set on Ch 3 or 4 or are you using Line in/aux?
Feb 19, 2008 | Televison & Video
Kodak EasyShare CX7330 Digital Camera Logo
217 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
