Question about Freecom MediaPlayer-3 Digital Media Player
Will not accept harddrive to watch films. hitachi l46vno5u
I NEED 4 DIGIT CODE FOR TALK TALK YOU VIEW BOX HUAWEI DIGITAL BOX REMOTE CONTROL TO CONTROL MY HITACHI L46VNO5U TV
2271,2238,2220,0000. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 07, 2015 | Hitachi Televison & Video
Beeping hard drive ?
Beeping or chirping?
Check it in a PC if you can. If its more of a chirp than a beep your HDD inside likely failed.
Dec 01, 2013 | Hitachi 2TB Touro Desk DX3 USB 3.0...
My hitachi tv wont play movies via usb??
this tv will only play mp4 video (MPEG-4) ONLY AND DOES NOT PLAY THE H.264 MP4 FILETYPE EITHER...ONLY TRUE MP4, BEST BET IS TO GRAB YOUTUBEDOWNLOADER (IT'S FREE) AND USE THE CONVERSION FEATURE TO CONVERT YOUR MOVIES TO THE IPAD VIDEO SETTING WITH SAME QUALITY AS ORIGINAL SELECTED...CONVERSION TAKES 30 SECONDS...BEST 100% GUARANTEED TO WORK ANSWER..I KNOW...I HAVE ONE CONNECTED TO MY 4TB HARD DRIVE.
Jun 23, 2013 | Hitachi Televison & Video
My vivo tv wont accept portable harddrive through usb ports
that because your TV or TIVO doesn't have the necessary decoder for the HDD and that's why it only works with the laptop
Feb 23, 2013 | Computers & Internet
55274-OEM-0011903-00107
http://uk.answers.yahoo.com/question/index?qid=20080820061943AANsZGh
IBM Thinkpad? Then post the MODEL NUMBER.
It's on the bottom.
Thinkpad T42?
http://support.lenovo.com/en_US/product-and-parts/detail.page?&LegacyDocID=MIGR-50075
This is an example of one of the harddrives in the list.
An Hitachi 08K9834 ATA 40GB harddrive,
http://www.shopping.com/IBM-HARD-DRIVE-40GB-5400RPM-08K9834/info
Hitachi - Manuafcturer
08K9834 - Model Number
ATA -100 - This is an IDE (PATA) harddrive
http://en.wikipedia.org/wiki/Parallel_ATA
It is NOT a SATA harddrive.
The answer is NO.
The laptop will not use a SATA harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 16, 2013 | Computers & Internet
Hitachi hard drive clicking and not working
1) A harddrive is built in a Clean Room. A room that is 99.9 percent dust free. Technicians going to enter the room have to don suits, and hair guards, plus walk through an Air Corridor.
2) Upon opening a harddrive it's 'Lifecycle' is done. The harddrive is no good now. There is a VERY small time limit to remove wanted personal data.
A) http://computer.howstuffworks.com/hard-disk.htm
B) http://www.youtube.com/watch?feature=endscreen&v=Kcb6a_LJaJQ&NR=1
C) http://www.youtube.com/watch?v=L4qBl8x3tC0
Regards,
joecoolvette
Jul 14, 2012 | Hitachi 14R9249 250 GB Hard Drive
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Watching film and hard drive stopped and no power .Recently every time I plug it in windows kept asking if I want to scan it , and it took a while for my computer to recognise it. Now there is no power ,...
There are considerable problems with Hitachi drives, this is not uncommon on older models. Remove the drive and take it to a data recovery specialist. Do not power up the drive.
Sep 13, 2011 | Hitachi Computers & Internet
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Need jumper settings for both hard drives. PCb board has been replaced. Cannot rememebr the orgional settings.
Master (M) on the harddrive that came with the computer, Slave, (S, or SL), on the 2nd harddrive.
Don't see M, S, and CS, on the label of the harddrive? (CS is Cable Select)
Sometimes it's right on the edge, where the 40 pin flat ribbon cable plugs in. It will be letters raised in the plastic, of the harddrive body.
To find where to set the jumpers for these harddrives, I suggest you look at the label. Since you had the Printed Circuit board replaced, I'm guessing you know who made it, and what the model number is.
Some harddrive manufacturers,
1.Western Digital
2.Maxtor, (Maxtor is owned by Seagate now)
3.Seagate
4.Hitachi
5.NEC (No longer in business)
6.Quantum, (sold out to Maxtor)
Here are three links that are videos, and may help with setting jumpers, and setting up those IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
(If you have SATA harddrives, do not touch the jumpers, if any are present! These are for the factory. With a SATA harddrive, you can plug it/them, into ANY available SATA header, {Connector}, on the motherboard. Doesn't matter!)
1.http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.http://www.youtube.com/watch?v=4inX3nC6M1E&feature=related
3.http://www.youtube.com/watch?v=KtEcwRqzeVo&feature=related
May 22, 2009 | Computers & Internet
Freecom MediaPlayer-3  Digital Media Player Logo
56 people viewed this question
Top Freecom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Freecom Audio Player and Recorder Expert? Answer questions, earn points and help others
