Question about Buffalo Tools 10" Sliding Compound Miter Saw With Laser Guide CMSS10UL
Is there a locking pin on the right side of the saw that lets the saw spring up?
  • 1,358 Answers
It should spring up by itself,it may be broke hence the name BUFFALO. there should be one to keep it down. it is next to the hinge.need to hold it down OR UP ? just use a black bundgie cord. jay
Posted on May 25, 2011
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
How do you unlock it so you can lift the blade up. Not in the manual
There is a small pin or lever on the right side, a few inches in front of where the hinge is. You have to pull the pin out about a half inch. But the spring that is trying to raise the saw will be working against you. So you have to push down slightly on the front of the saw with your left hand while you pull out the pin with your right hand.
Sep 15, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
Cant pull out locking pin on miter saw
There is a heavy spring which is trying to hold up the saw that is working against you. Press down on the handle of the saw so that it moves down a little, now you should be able to pull out the pin.
Good luck.
Jun 13, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
DW938 reciprocating saw only works if turned on right side and not at all if turned on left side. Motor appears to be arcing if and when it works. Moderately used and never dropped or wet.
There are a set of contacts or brushes that are spring loaded and press against the motor shaft one from each side, when you lay it on the side that works the brush with the broken spring is on the top and gravity lets it fall in place so it will work, but the arch is because the spring is not there to hold the correct pressure on it. Check the instruction or your local tool shop for the brushes and instructions on how to replace. Easy fix and no need to replace the tool.
May 18, 2011 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
How do u unlock a 10'' benchtop compound miter saw
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
Jan 12, 2011 | Makita 10" Compound Miter Saw LS1040
Looking for release mechanism on a 10in craftsman miter saw ( borrowed the saw and cant figure out how to make the blade go up
There is a little pin, usually black and usually on the right side near the hinge that you pull out about 1/4 inch. Push down slightly on the handle to take the spring pressure off of the pin so it will be easier to pull the pin out.
Dec 23, 2010 | Garden
How to release the cutting arm of ryobi cut off saw
There is a little pin that holds it down so you can carry it by the handle. The pin is near the hinge. It's probably black and probably on the right hand side. You should press down on the saw to relieve the spring pressure which is trying to raise the saw. This will make it easier to move the pin. You don't remove the pin, you just pull it out about a quarter inch. Good luck, Al K
Nov 16, 2010 | Garden
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
Craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Sep 12, 2009 | Saws
Locking mechanism on miter saw.
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Jan 03, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Buffalo Tools 10" Sliding Compound Miter Saw With Laser Guide CMSS10UL Logo
182 people viewed this question
Top Buffalo Tools Saws Experts
Tom Chichester
ray gallant
Are you a Buffalo Tools Saw Expert? Answer questions, earn points and help others
