Question about Bosch Drills
I just recently purchased a Bosch 11536C-1 36 Volt Lithium Ion Compact Rotary Hammer Drill. I've used it to drill approximately 25 - 30 holes so far. The last time that I removed the drill bit, the "inside the drill end" came out with a considerable amount of oil or grease on it from where it attaches inside the drill. This has never happened before, what does this mean? \r\nThank you.
    Scholar:
  • 123 Answers
You might have oil escaping past the ram seal. Other than grease for the chuck you should not have anything getting on your bits. I would have it checked out since it is so new.
Posted on May 28, 2011
Milwaukee 18V Hammer drill shuts off while drilling
Brushes to the motor could be the cause or heat sensor in the battery pack it switches off or even bad connections on motor check the spades connections could be loose
May 13, 2017 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
18V Lithium-Ion X3 Hammer Drill
I always where possible dismantle new and sometimes older small power tools with gear boxes and replace or add to the grease with Molybdenum disulfide grease which reduces the friction a surprisingly large amount therefore increasing the available power at the tool tip and extending the life of the tool by a insignificant amount .
It is particularly noticeable in my Bosch jig saw.
Jun 03, 2010 | Ridgid 0.5-inch 18-volt Hammer Drill
When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Aug 14, 2009 | Milwaukee 0824-24 V18 1/2" Hammer Drill...
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Aug 27, 2008 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Drills Logo
148 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
