Question about Vizio VW26L 26 in. LCD TV
Visio screen light goes on but the screen does not power up. No picture just black
    Genius:
  • 1,156 Answers
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem.....
Posted on May 25, 2011
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Visio VX32L has a black screen, appears to power on but picture.
Any swelling on a cap is bad sometime you wont see swelling ontop sometimes its on the bottom, I suggest replacing those caps then try again make sure you discharge the caps as well.
Also make sure its the right caps too!
1000uf 6.3volts or something like that. Ebay a good source for caps and amazon.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Dec 15, 2015 | Televison & Video
How do I fix my Visio tv when the screen suddenly goes almost black and white?
Hi Evan
Essentially it's a computer inside a modern Flat Screen TV these days. Not a lot that the average person can do...
But... if you feel capable of opening the back....
Once you get inside and check for loose or poor connectors,
I would be looking for leaky Electrolytic Capacitors.
Usually in the power supply section.
Look for brown fluid leaks on PCB & a very slightly puffed out or bowed top on the cap. (ready to explode)
Take a picture of suspect. Take note of Polarity (black stripe) & write down uf & voltage & temp values.
eg 1000uF @ 25v
To prove you are on the right track, you can connect a similar rated Cap across (in parallel) the existing Cap.
Depending on space etc. Even by short extension wires.
Power up & see results. Fault Gone or Not?
Then...
Unsolder & Remove suspect Cap & try to replace with higher voltage rating & slightly higher uf capacity depending on space available around the components.
Good Luck
See
How to Replace an Electrolytic Capacitor
Oct 30, 2015 | Vizio L37 Television
Power light but nothing else on vizio vt470m?
Power board is of course most likely problem here and I presume you found no puffed up caps on the board.
May 16, 2012 | Vizio VT470M 47 in. TV
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
No power on my Visio 32 flat screen
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Nov 17, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio VW26L 26 in. LCD TV Logo
362 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
