Question about Samsung OKIDATA - OKI C5200n - Printer
Have purchased some cartridges (compatable) for my Oki C5600 but i am unable to use them to to microchip.Is there a reset method or do i need to buy more chips?
  • Samsung Master
  • 4,338 Answers
Reset the Drum Counter:
a. Press the MENU 1/Menu 2 button while turning the
printer on.
USER MNT appears on the display.
b. Press the MENU 1/Menu 2 button until the message
corresponding to the drum you are replacing
appears. For example, if you are replacing the
magenta image drum:
MAGENTA DRMCNT
RESET
c. Press the ENTER/POWER SAVE button.
RESETTING briefly appears on the display.
d. Press the ON LINE button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 25, 2011
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Apr 20, 2009 | OKI C5500n Printer
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Apr 12, 2009 | OKI C5500n Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Hi oki c5600. printing A4 size labels succesfully until printing image with large areas of colour. "Smearing" gets progressivly worse as the doucuments goes through
that means that your ink and the label materials are not compatible. you may need to use less ink, or a more porous label facing.
Aug 20, 2008 | OKI Office Equipment & Supplies
Samsung OKIDATA - OKI C5200n - Printer Logo
446 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
