Question about Whirlpool Dryers
Have a WED5840SW and the button you push to turn it on will not turn it on. I hear a bit of a buzz when I push it, but the machine does not fully turn on. ??Moto..belt?? HELP before I have to spend all kinds of money
    Brigadier General:
  • 3,301 Answers
After it stops when fully opened it will not go back down when I push the button. Like it doesn't know it should reverse directions!
It can be a relay in the electronic circuit or if you can hear the motor buzzing its the limitswitch at the endpoint of the door that does not interrupt the run-up current to the manual operation.
May 24, 2016 | Building Materials
I have a Kenmore elite washing machine and when I power it on it goes on . then I push the start button and I hear a humming noise and the timer is flashing . Please help.
oh oh a humming noise usually not a good sign, and usually is from a bad motor with windings that have gone out. in ur case u may be hearing what u think is a humming noise? but in reality may be a bad push start button which can sound like a hum but is more of a buzzing sound
Feb 19, 2015 | Kenmore Washing Machines
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Quinny buzz clip to open missing
Hi Ellen
The transport clip is a safety measure to ensure the chassis remains closed in transit - like when it's in your car boot, to make sure it doesn't unfold while you're driving. It is available as a spare part item, RRP 10GBP (full info can be found on our Note for Buzz spares)
The click noise you hear when you unfold the chassis is not related to the fold lock. This is a safety measure designed to warn you not to continue forcing the chassis open as the locks are not completely disengaged ready for the chassis to be unfolded. By forcing beyond this noise you may cause damage to the fold / unfold mechanism. If you hear the click, allow the chassis to fold again and try again. Ensure the button is fully depressed / the other side button is fully pulled forward before attempting to unfold again and you should not hear a click. If you do, it would be advised to book the chassis in for inspection & repair required.
Quinny Buzz Quinny Buzz Xtra Spare Parts
Repair Charges Effective Immediately
Mar 20, 2014 | Baby Gear
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Oct 22, 2009 | Frigidaire Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Dryers Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
