Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I recently installed a new intermatic Timer on my pool, the timer mechanisim does not appear to be working, any suggestions on troubleshooting?
  • 1,384 Answers
I USED TO SELL THE MOTORS FOR THESE ON EBAY.. ONE PICTURED.. TAKES A WG1570-** "115V" OR THE WG1573-** ITS 208-277 VOLT.. YOU CAN LOOK THREW THE LITLE WINDOW TO SEE THE GEARS MOVING IN THE CLOCK MOTOR, YOU MIGHT TAKE OUT THE MOTOR AND BLOW IT OUT WITH COMPRESSED AIR. FREE.. THEY SELL FOR 24.00 WTH 4 SHIPPING.. BEST OF LUCK... OH AND A DROP OF OIL NOW AND AGAIN ON THE YELLOW WHEELS SHAFT IS A GOOD IDEA.. JAY
Posted on May 25, 2011
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
http://waterheatertimer.org/Intermatic-freeze-controls-and-parts.html#1202
http://www.amazon.com/dp/B003Y5EY6E/?tag=waterheaterti-20
http://waterheatertimer.org/images/178T24-thermostat-wiring.jpg
http://www.amazon.com/dp/B003P52CKS/?tag=waterheaterti-20
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic pool timer instructions
Timer is not identified. Do you have control center that controls heater, pump etc, or individual timer that controls pump?
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment.
Is this a new installation? Or did timer work before and stop working? What voltage are you working with?
Jun 24, 2013 | Intermatic Hardware & Accessories
Pool time switches pool on, but off does not trip off, and can't do it manual. When I push it on off, the pool pump tries to stop but continutes running. Have to use breaker box.
Model number of timer is not known.
Is this new installation? Or installation that worked before and recently stopped working?
If the manual override lever on timer does not turn Load on-off, then 1) wiring is wrong or 2) timer has gone bad or 3) pump has a short.
I suspect a short since you say the pump 'tries to stop running.'
Copy following links for troubleshoot walk-thru, and correct wiring:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
Manual switch works timer doesn't.
Timer that worked before and stopped working: could be clock motor or trippers
New timer installation: possibly the wiring from breaker box and wire to Load are reversed.
Open following links to troubleshoot Intermatic timer.
Jul 27, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Purchased new intermatice pool timer and it will not turn pool on but will turn pool off.
Timer is not known.
Timer is probably not wired correctly, or on-off trippers are not on the dial.
Add a comment with model number that appears on inside of timer door.
Jun 18, 2011 | Intermatic Hardware & Accessories
Timer will not shut off Pump with tripper.
T40004R 100 amp control panel has one 240Volt T104M timer mechanism.
1) If this is new installation then timer is probably wired wrong.
2) If timer worked before and stopped working, and timer dial is rotating and keeping good time, sounds like you need set of 156T1978A trippers.
3) Open following link for timer troubleshoot and trippers:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Jun 18, 2011 | Intermatic Timer T40004RT3 300 Watt Pool...
Intermatic pool timer E10694 does not turn on. It shuts off okay.
Open following link for troubleshooting checklist:
If dial is rotating, then tripper might need to be replaced.
The problem here is I cannot identify E106 timer
Intermatic product Index, and pool and spa catalog do not show that specific model among digital or mechanical timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Maybe you have T106 2-speed pump motor?
Add a comment with in-focus photo of timer you posted on Flickr for possible identification.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Intermatic T104 24h 208-277v Mechanical...
I installed a new timer today, it works ok but ...
It would be very handy to know the timer model number that appears inside door of timer.
Open following links to help get started on the troubleshoot:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
May 20, 2010 | Intermatic R8806P101C -...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
101 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
