Question about Refrigerators
My Frigidaire freezer is allowing air to enter around the seal. Can the seal be easily replaced by a homeowner and where do I get the seal?
Speed boy
  • 76 Answers
SOURCE: GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
Posted on Sep 10, 2008
  • 56 Answers
SOURCE: Sealant Choice for wires entering freezer compartment?
The factory uses PERMAGUM. It can be picked up at most HVAC supply houses or a Johnstones supply.
Posted on Dec 03, 2008
  • 31 Answers
SOURCE: 4 yr old kenmore frig/freezer (on top) gasket
try using a hair dryer on the door seal to get it to take proper shape. I was a service tech for years, and this worked every time.
Posted on Mar 14, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
  • 212 Answers
SOURCE: Replaced magnetic seal on freezer and door still
depending on where the gaps are your hinges are warped. losen up the hings bolts and adjust hinge then hold in place and retighten bolts
Posted on Jul 02, 2009
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire freezer LFFU14F5HWN fan not running or cooling
Hi djgecko - Here are a few simple troubleshooting tips that may help you resolve this issue:
· First check clearances around your freezer. There must be adequate space around a freezer with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the unit.
· Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the freezer. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure the freezer is level and keep food and containers from blocking the door closing.
· Check the door seal. You do this by placing a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket. (Most appliance owners can easily do this without any tools or sealant.)
· Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
· Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the freezer will not get cool.
· Double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Apr 17, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
Tempt setting
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 19, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Frigidaire freezer always running
Hi Edward - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 13, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Replaced gasket twice; still ices up around door.
If you replaced your door gasket and your absolutely sure that its sealing properly, then it might not be coming from your door. Ice builds up when warm air enters the fridge and the condensation freezes inside the freezer. The biggest suspect for warm air entering into the fridge is a faulty door gasket. However there can be another cause. If you remove the back panel of your freezer you should be exposed with the wires that come into the freezer and power the different components inside. The entrance point were the wires come in is insulated with a type of clay that prevents moisture from entering. However if this clay becomes loose it is possible for moisture to enter and start icing up. If you can remove the panel yourself safely without hurting yourself or damaging the fridge i recommand trying this first. If you don't feel comfortable doing this i recommand having a service technician taking a look at it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
THE SEAL ON THE FREEZER DOOR IS NOT HOLDING, CAUSING FORST TO FORM IN THE FREEZER TO THE POINT THAT THE FREEZER STOPS WORKING.
Well without knowing the model or configuration, (upright, or chest), there are only a few possibilities. 1 - if the seal is magnetic, then its lost is magnetism. 2 - if it has electric door seal heaters, then they are defective, and need to be replaced. 3 - if the seal itself is damaged, ripped or torn then the air penetration will cause this, espescially if the surrounding air is humid. 4 - If it's an upright, then the unit might not be leveled properly to allow sufficient closing pressure.
Sep 26, 2009 | Frigidaire FRS26ZSG
Ice keeps accumulating in back of fridge. We've tried cleaning drain but it doesn't seem to help.
If the drain is clean and there is sufficient space for air to flow around the food, the only thing left is to replace the door seal. It is allowing moisture to enter the freezer. The fan inside the freezer, actually burns the frost off of the food. If the seals are bad, it can never catch up.
Sep 17, 2009 | Liebherr Refrigerators
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
