Question about Dryers
How to install capacitor to fisher & paykel ED56 AU dryer. There are no markings. machine has yellow & blue wires
  • Anonymous Mar 16, 2014
    how do I set the time on my Fisher & Paykel Saffron oven?
    Sergeant:
  • 351 Answers
If the cap has two terminals it doesnt matter where you put the wires
Posted on Aug 28, 2008
My fisher paykel ed56 wont go lights and buttons work wondering is there a reset button somewhere please
it may not be in that area your problem lies,a common problem is the capacitor. with the door open and the door switch activated by using a small screw driver,push start and try to rotated the bowl help it get rotating if it goes around with a bit of help to get it going then its the capacitor, easy to replace
Oct 18, 2016 | Fisher and Paykel Dryers
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
How do you put a capacator in to a ED56 Fisher & Paykel Dryer
I assume you have found that your capacitor has blown or open circuited? If you take the back off the machine, you will see the capacitor fitted near the motor. It will have a clamp around it or may be "stud" mount. The end of the Capacitor has a stud that goes through the panel and a nut is on the other side.
Sep 25, 2014 | Dryers
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
My F&P ED56 dryer just hums when it is turned on. The lights come on and it hums, but it doesn't turn or blow air. We have checked the belt (that is OK), the drum can spin by hand, there is no lint...
sounds like it maybe the motor, here are other reasons the drum won't turn and how to open the dryer. Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 28, 2010 | Fisher and Paykel Dryers
Dryer does not turn on
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 08, 2010 | Fisher and Paykel DG05 Gas Dryer
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Mar 06, 2010 | Fisher and Paykel Dryers
Fisher & Paykel Electric dryer wont tumble
I had the same problem,fixed it today with a replacement capacitor,cost $10 2nd hand (only cos I couldnt find a new one today and wanted it fixed now!)Unplug appliance, took off the back panel,underneath the motor on bottom left is the capacitor,remove the 2 wires, pull the capacitor out its bracket,replace,refit the 2 wires,replace back panel and Badabing Badabang!! My machine is working to full capacity again.
Pays to check out these forums doesnt it!!!
Oct 09, 2008 | Fisher and Paykel DGGX1 Electric Dryer
F&P ED56
see if the jockey arms are hitting the drum or the capacitor is losse (if the dryer is upside down).hope this helps
Oct 20, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
647 people viewed this question
Top Dryers Experts
