When I turn the tv on there is no picture. I can see the green light at the bottom next to the power button is on but there is no picture. You can hear the channel that is on but there is no picture. Its a Mitsubishi big screen tv made in feburary 1996 model number TS-4557 serial number 005635
    Genius:
  • 1,156 Answers
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help to fix the problem.....
Posted on May 25, 2011
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Polaroid 4011-tlxb. Power to tv and it was turning from red to green light when you press power button but no picture. Pressing any buttons on tv or remote and nothing was happening. Replaced power supply...
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | Polaroid TLA-04011C 40 in. LCD TV
No power no picture
power supply is bad.. also you need to check your convergance.
Aug 29, 2009 | RCA D52W23 52" HDTV CRT TV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Coloration - poor picture
TRY UNPLUGGING SET FOR A FEW MINUTES...PLUG IN LINE CORD WHILE HOLDING PRESSING POWER BUTTON..IF THIS DOES NOT WORK..CPU BOARD IS FAILING...P/N 667-L32K5N-56I...TRY CALLING MCM FOR PARTS AVAIL/PRICE...JOE ACE
Jun 05, 2008 | Insignia IS-LCDTV32 32 in. Television
No Picture, Indicator Light Green
If your TV is a year old or more, chances are that the power supply is starting to fail on your TV, causing all kinds of erratic behavior up to the point of not turning on anymore.
I service these power supplies since it does not look like there are many service parts available anymore. The only way to get this TV functional again is to repair the power supply to the component level.
May 11, 2008 | Protron PLTV-32 Television
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
