Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Why will the brushes move mannually but not when the bissellis on
  • 276 Answers
The brushes will only move when the machines handle is reclined.
Posted on Jun 01, 2011
Squealing when Brushes are moving
they have bearings at the ends of the brushbar it will be them that need changing
Feb 24, 2014 | Dyson DC17 replacement BELT GEARED DC-17...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
The rotating brush is not moving.
is the dyson brush belt-driven like most other vaccuums? broken brush belts usually cause that. they are easily replaced at most dept stoes or vac stores.
Apr 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a bissell proheat turbo 2x microban steam
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hgkklgh
Feb 02, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes are too low and prevents smooth movement of the machine
The brushes should be free moving, up and down. They float while moving the cleaner with the motor running and the brushes spinning.
Oct 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The brushes will not turn even though I have the switch on for the brushes
When you move the swwitch to on, you are moving a baffle to allow air flow into the turbine to rotate the brushes. try to move them by hand with the machine off. if you cannot the turbine nees service. if you can check the tank lid is on, foam filter for dirt.
Sep 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
May 01, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
29 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
