Question about General Electric Refrigerators
I have a GE side by side refrigerator model # GSS20IEMBWW and the ice maker was taken apart and I cant figure out where the wire spring goes to reassemble the ice dispensor i need a manual
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: user manual for GE Ice Cream Maker Model 106765
Hi
Thanks for using FixYa. You can download the user manual for GE Ice Cream Maker Model 106765 from the following link—
GE Ice Cream Maker Model 106765 User Manual
Please do rate the solution.
Thanks
Rylee
Posted on Aug 22, 2009
SOURCE: Admiral Refrigerator makes hollow ice
If your filter is over 6 months old, try replacing it first. Its time for a new filter anyway. Thats when I usually know its time for a new filter.
Posted on Dec 30, 2009
  • 6 Answers
SOURCE: kenmore side by side refrigerator
sounds like problem is in display activatin switch check plug under hinge cover at top of freezer door otherwise new diplay panel needed
Posted on Mar 25, 2010
The ice maker in my GE model #TFX20JRBK-AA will not stop making ice. What part do you think I need to replace to solve this problem?
Either the ice maker bucket is not placed properly.Remove it out and reinsert it.Or the the feeler arm is broken.So the ice maker is not detecting that ice is made and it goes on making ice.-------- Click this for troubleshooting:--- http://howtobyme.blogspot.com/2011/07/ge-refrigerator-ice-maker-will-not-stop.html ---------- This will help.Thanks.Helpmech.
Jul 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator DSS25PFMD, and a problem with the ice maker: the spring "bar" in the back that triggers ice being made (or not, when the box is out) has ice accumulating on it and it's...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 15, 2011 | GE GSS25JEM Side by Side Refrigerator
Broken auger on ice maker needs to be replaced. Can't get apart.
You will have to remove the E ring that attaches to the end of the auger before you can pry the pats apart.
Please rate solution
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ICE MAKER, VERY LITTLE ICE,
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Jul 20, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
85 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
oldsquare1
Level 1 Expert
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
