Question about Bosch Exxcel WOP 2400 Top Load Washer
Bosch wok 2001. my machine stops on 03 and flashes both the number and the pump light
5 Suggested Answers
SOURCE: Washer stops prematurely with code 03
I've had a WFK2401 since 2002. I have had this issue for years. I've manually drained this washer so many times the floor is warped from occasional spillage. 03, eight aggravating beeps that go on forever, nothing in the trap. The problem, in my case is in intermittent, averaging about one in four times. My electronically-fluent son suggested that the control board might be dirty so I disassembled the top and extracted the control board. There was obvious black soot on the components in the vicinity of the transformer. The soot was not contamination from the environment, the soot was from a component on the control board that "exploded". I had a serviceman in my home several months ago to repair another appliance. All he said about the Bosch was, "...just wait until you have to replace the control board". Part cost is about $300.
Posted on Sep 24, 2007
  • 1294 Answers
SOURCE: My washing machine bosch 2401
First unplug the machine; then check all your connections and harnesses. Possible while you worked some wires could have come loose. Re. the code look in your users' manual............or surf on this site going to Bosch washing machines, from 'washing machines' above.
Please tell me somethng after you get this - yes, no or whatever...... I have quite a few solutions for which there is nothing............dont speak gama, type!
Posted on Jun 03, 2008
SOURCE: bosch wok 2001
Our Bosch washingmachine also suddenly went wrong and gave the code 07. According to the fault book the drum was not shut properly. This was not the case. The brushes of the motor had worn, these needed replacing. It now works again.
Posted on Aug 31, 2008
  • 6277 Answers
SOURCE: ukWhen the cycle changes from
My Bosch WFF2000 series fault light decode list shows those 2 lights only being ON and not flashing so I do not suspect it's the same fault (which is to do with the machine heating water at the wrong time).
No promise but I would suggest as a first step that you clean the drain motor lint tray/filter just in case that is what the machine is indicating for you to do.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 17, 2011
What the code 03 means
if this is a bosch machine -03 error code is the drain. starting at the tub disconnect the drain hoses and check for blockages-also clean the trap and the pump-also are you using the correct detergent-cleaning should keep you running ,if the machine stops then you have a pump problem-cheers Denny
Oct 19, 2013 | Washing Machines
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Washing machine, Bosch WOK 2401 Doesn't wordk 3 lamps are flashing: wassen , spoelen , centrifugeren/pompen. (wash,rins, pump?)
Washing machine, Bosch WOK 2401 This video will show you how to change the pump washing machine
Jan 09, 2011 | Bosch Washing Machines
My Bosch WFK 2401 keeps giving me the 03 error message, the pump looks fine when I drain it manually (which takes 1/2 and hour!, now I don't bother draining it completely, I just drain a bit of water from...
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Oct 05, 2008 | Bosch Washing Machines
Bosch wok 2001
fill the whole system with hot water and add a bottle or two of mr muscle lime scale remover, leave to soak then drain via the bottom
May 15, 2008 | Bosch Exxcel WOP 2400 Top Load Washer
This was always caused by a blockage of the pump. The water isn't able to be pumped out so the sequence stops rather than continuing with the wrong water still in the machine.
Our solution was to manually drain, then open the pump area and remove the coins that always were the cause of the blockage. Wish we could get our (grown) kids to stop putting pants with full pockets in the machine!
Of course, I am looking at this site today because the machine no longer turns the drum. A repairman visit resulted in the diagnosis that the power control module AND primary motor are burned out and need replacing, at an estimated $800.
Aug 21, 2007 | Bosch WFK 2401
Bosch Exxcel WOP 2400 Top Load Washer Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
