My ibm think pad a22m doesn't turn on . the fan isn't working have power but won't stay on
  • 56 Answers
Chances are that if the fan isn't working then its over heating and shutting down. Check to make sure there is no dust or pet hair clogging it up. If there is then try and clean it out with compressed air. If there is no obstruction then the fan may have died on you. Only thing to do is look into getting a new fan or take it to a repair shop.
Best of luck
Posted on May 25, 2011
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
My microphone won't work
Maybe the microphone is damaged?
Dec 07, 2011 | IBM ThinkPad A22m 2628 Notebook
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My nb A22m doesnt turn on, blink HD light only, with/without AC/battery/HD. Green power light is on.
I think the problem will be due to any hardware mistakes or battery problem
if it is hardware problem u have to give ur laptop for repairing
if it is a small problem it will not cost more
so get ur laptop cheked
Jun 24, 2009 | IBM ThinkPad A22m 2628 Notebook
My laptop doesn't start when i turn on it
Are there any lights that come on? Be more specific with your problem. Ray CompuGuy44
Jun 21, 2007 | IBM ThinkPad A22m 2628 Notebook
Need sulution for fix Laptop IBM A22m
try an externial mon. if you have display. this could mean the inverter may be bad. try that and see if it works.
Nov 27, 2006 | IBM ThinkPad A22m 2628 Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
