Question about Garden
My Weed Eater runs for couple of minutes and stops after ward. After keeping for while , you can start again but stopr s after couple of minutes again
    Guru:
  • 479 Answers
The problem is probably due to a fuel flow problem, but could be caused by the insulation of the spark plug breaking down when it gets hot. Try changing the plug and if this doesn't work have a look at these tips:
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Hope this helps!
Posted on May 25, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Starts right up on choke. then run inrun position for a minute and have to go back to choke to keep it running ,then it runs fine for a couple of minutes and have to go back to choke and start all over...
    Try cleaning or replacing the air filter.
    When you are in choke, it is not using very much air, it is running a very rich mixture. When you switch it to run, then it demands more air and it sounds like its being starved.
    Jun 08, 2011 | Poulan Weed Eater No Pp446t 952802025 31cc...
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Sthil weed eater will not run when hot?
    you will need to replace you muffler so the machine can get rid of it's exhaust
    Jul 23, 2009 | Garden
    Weed eater starts, runs 5 min. then cuts off
    The gas cap may be clogged.
    The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
    You may also check the air breather, it may be dirty as well.
    Just let me know if you need further assistance.
    Jim
    Jun 28, 2009 | Poulan Pe550 Gas Edger
    Weed eater GTI 17 won't run on high speed
    A couple of things may work...
    Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
    Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
    May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
    Weed eater does not start
    I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
    Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
