Question about Medion (40010998)
I HAVE NO NEW XP WINDOWS RECOVERY CD FOR MY MEDION MIM2220 SO I CANT START WINDOWS , WHEN I TRY TO INSTALL FROM RESTART IT COME WITH THIS MESSAGE WHILE TRYING TO BOOT ( AN ERROR HAS BEEN ENCOUNTED THAT PREVENTS SETUP FROM CONTINUING ONE OF THE COMPOENTS THAT WINDOWS NEEDS TO CONTINUE COULD NOT BE INSTALLED DATE ERROR ( CYCLIC REDUNDANCY CHECK)
    Problem Solver:
  • 19 Answers
Do you have the original installation disk that came with the computer? You can try to boot from that CD and do a repair installation. The Cyclic Redundance Check (CRC) error refers to the media the computer is trying to access (either the CD or the hard drive). Try booting into Safe Mode (reboot and press F8 repeatedly until you get a boot menu). From Safe Mode run a checkdisk (chkdsk from command line) on the hard drive to find and repair any found disk issues.
Posted on May 25, 2011
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 23, 2011 | Gateway 704GE PC Desktop
How do i install windows xp when it wont let me. i reformated my medion 4215 computer and have problems with putting on win xp i get a message when i try to install xp setupdd.sys
Hi
thank you it would seem that your recovery media i.e. CD or hard driver recovery is corrupted and will need to be replaced as it cannot read the file mentioned
Please replace the CD
Regards
Shauqat
Jun 09, 2010 | Medion (20023245) PC Desktop
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 21, 2010 | Acer Aspire 4720 Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Press f11 to start recovery doesn't work
do you have a recovery cd or a copy of windows xp, try pressing f12 to get to a boot menu or f8, to get to a safe boot option or a last previes known good option, or some thing like this. press these options on off on off just before it goes to load the windows. try that hope it helps
Nov 30, 2009 | Cameras
Windows xp will not install
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Oct 19, 2009 | Microsoft Windows XP Home Edition
Cant start computer
Try this:
boot order in the system BIOS. Check your system documentation
2. When you see the "Welcome To Setup" screen, you will see the
options below This portion of the Setup program prepares Microsoft Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the
Recovery Console, press R", (you do not want to load Recovery
Console). I repeat, do not choose "To repair a Windows XP
read the Warning listed later!!
When your system reboots, Do not press any key to boot from CD when the message appears.
Feb 12, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
How do I use recovery partition in the Medion mim2220 laptop. I need to restore the complete laptop.
The best way to restore the computer back to its original state is to just install its original windows with an Install disk. My Restore was only good for one use and I used that up shortly after I got the computer. What ever your system is rather it be Mac or Windows, just reinstall windows and that will work perfectly. Good Luck.
Oct 28, 2008 | Computers & Internet
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
NO SOUND DEVICE FOUND AFTER RELOAD WINDOWS XP
hi reloaded windows xp on medion mim2220 laptop unable to find sound device to work sound for my laptop cant play any music can you help please
Feb 25, 2008 | Medion (40010998)
Computers & Internet Logo
230 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
