Question about Vacuums
I have an Lithonia Emergency Light (ELU-8). The battery is reading 13.56 volts, but when I push the test lamp the lights do not light. I question thst both lamps a bad. These were istalled in 1988.
4 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: a 40 W fluorescent lamp
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Posted on Feb 19, 2011
Asbestos 56
  • 191 Answers
SOURCE: My simer ace in the
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Posted on Jun 09, 2011
SOURCE: I need the circuit diagram
i nee the ckt diagram
Posted on Dec 19, 2011
Red "testing" light comes on when a battery is inserted and flashes continuously. Green light does not come on.
Actually, this is normal. You have to wait for the test to complete, and then it will charge your battery.
Dec 07, 2015 | Ryobi P113 18 Volt One Charger 140501001
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
Jun 09, 2011 | Vacuums
My Breville portable vaccum cleaner BHV9 stopped working. I haven't used it for the last 1 year. is it the battery?
good day..
try to see the LED indicator of your vacuum if it is light to low battery charge it...if the indicator is not lights-up your battery is drain.. because when the battery is not used for the long time it is got drain.
try to remove the battery and test it using tester the reading of your tester must 12vdc if not or almost zero reading replace it
if the indicator is on normal lights so your battery is good and the motor is not function..
try to lubricate it with the oil to the bushing
thank you and good luck
Apr 06, 2011 | Vacuums
Universal Lighting and Decor company: i have one of their Halogen Three Light Torchiere and Reading Floor Lamp and the Torchiere or top light has a defective socket which works only intermittently. It...
Large cities have "lamp" and/or "lamp shade" stores.
If you will find one, you might be able to buy the parts you need.
Realize that if it be made in China, parts might not be available.
God bless your efforts.
Jul 03, 2017 | Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
