Question about AdobeAir Heating & Cooling
Need specs on Model ED 430 Swamp Cooler, assuming this is the down draft model as opposed to ES 430.
TheMobilian
  • 8220 Answers
SOURCE: evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 16, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 340 Answers
SOURCE: Breezair swamp cooler parts
applianceparts.com try the manufacture web site johnstonsupply.com should have a pump you can make work. Tom
Posted on Jun 28, 2009
mrjfisher
  • 141 Answers
SOURCE: Got an Adobe Air Swamp Cooler Model # P228101A. Lo...
Indoor Comfort Evap Cooler & AC Parts, Phoenix AZ 85021 2001 W Cheryl Dr, Phoenix, AZ 85021
www.merchantcircle.com › ... › AZPhoenix85021
They say they have parts for your unit.
Posted on May 19, 2010
  • 10865 Answers
SOURCE: I have a Westwind Convair
hi.
here is the company contact info. http://www.cylex-usa.com/company/convair-cooler-corporation-5048927.html
call them to order.
Posted on Sep 02, 2010
ADOBEAIR MODEL # P400B NEED MEDIA PAD
I have a adobe air model rw 4500 need side to hold pad.
Jul 31, 2011 | AdobeAir Mobile Swamp Evaporative Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
PARTS FOR A ADOBE AIR
Need the part that holds the pads.
Jun 30, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Evaporative cooler pumps in dust
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
108 people viewed this question
Top AdobeAir Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
