Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
My toilet is having a small leak from the cystern which meant the saniflo switched on, on its own, every 24 hours or so. I switched it off at the mains but had not realised about the leak so the toilet bowl filled up. I switched the saniflo back on and it is just making a loud noise now and not pumping. presumibly the unit filled up with water too when I turned it off. How can I get it working again.
  • 1 more comment
  • yvonne_schof May 26, 2011
    Thanks. However the problem now is not the leaky cystern but the saniflo. Because I switched it off and I think it must have filled with water and not being able to pump out, it is no longer working. When switched on the saniflo just makes a loud noise like a motor but the pump does not pump when I flush or use the sink. Could the saniflo be full of water and if so how would I get it out. Thanks
  • yvonne_schof May 30, 2011
    I have kept the machine switched off for a day and turned it back on and it still made the noise. Turned off again and done this for a few day. It is now all ok. It probably just needed time to drain the extra water out of the pump. No need for a new pump. If anyone else has this problems just tell them to turn it off, be patient, wait, turn on and off again until works ok.
    Sorry but I don't think any of your experts understood the problem. Anyway, I have left the pump turned off for a day, turned it back on, and done this a few times and now everything is working fine. I think the pump got full of water and couldn't cope. All well now.
  • 17,970 Answers
About leak, it may be that the washers are worn out, or you might have the nut too tight.
If the pump isn't working, the length or height of the installation is over the specification, or there are too many bends/elbows or the pump chamber is blocked. First try to check this and the right position and installation of the components (click over image)...
Additionally, I suggest check the troubleshooting section in the user manual: saniflo.co.uk/Downloads.
Keep us updated.
Posted on May 26, 2011
  • ZJ Limited
    ZJ Limited May 30, 2011
    Well, this is a good new. Thank you for using Fixya.
    Master:
  • 448 Answers
This is what i found to be the problem the plunger that is hooked to the handle has
sediments around the plunger and the plastic peace that the plunger seals to all of
this needs to be cleaned and you will find it wont come on by it self any more
i hope this helps you
bob
Posted on May 25, 2011
  • robert DIBBLE
    robert DIBBLE May 27, 2011
    if the pump comes on but doesnt pump water you have 1 of 2 problams
    1 some thing is holding the impeller thus wont pump
    2 the motor is seezed and time to get a new one.
  • robert DIBBLE
    robert DIBBLE May 31, 2011
    im sorry i couldn't help you maybe next time bob
Why does it leak from the top outlet?
  1. SANIFLO upflush toilet - YouTube
    ? 6:14
    www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti
    Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Jul 10, 2015 | Saniflo Plumbing
I have just bought and installed the newbury close couple tiolet but when i flush it there is water leaking from the bottom of the cistern, but it only happens when i flush it any hlp would be great.
You need the proper wax ring to seal the toilet to the flange. Remove the toilet and check the wax ring. If it isn't compressed, get a spacer and a thicker ring.
Dec 05, 2014 | Home
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Jul 17, 2010 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflo keeps coming on about every hour on its own and we cannot stop it making an awful noise
Suspect that you may have a leak at the flapper of the toilet bleeding water into the holding tank causing the pump to run unnecessarily.
Replace the flapper and clean the mating surface.
Jan 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo works in short burst when not flushed eg in night
Sound to me that the toilet is over filling and in doing so water will over flow down the pan. This is definately what I would check first!
Jan 27, 2009 | Saniflo & Saniplus& Macerator Pump
Leaking cystern
turn water off flush scoop out water remove 2 screws on side of toilet lift toilet off clean replace wax ring reinstall
Jan 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
160 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
