Question about Magnavox 37MD359B 37 in LCD TV
My tv keeps cycling through colors and grey screens. I cant shut it off by the manual power button and get no response from any other buttons on the tv console. Its like watching a slide show. Not sure where the remote is. the dvd player was the only thing in use on this tv. I took out the dvd that was inside, hoping that would change something, but nothin
The TV is in Calibration mode. Take the original remote and press (Arrow up) (Arrow down) then (The power button on the TV) ((NOT ALL AT ONCE BUT IN ORDER)). Do it over and over if you need to.
Posted on Jun 08, 2014
  • Diamond Banks
    Diamond Banks Sep 16, 2015
    Thanks a bunch
  • Nelson Acosta
    Nelson Acosta Jan 20, 2017
    IS THERE ANOTHER WAY TO DO THIS WITHOUT THE ORIGINAL REMOTE CONTROL AND IF NOT CAN I SOLVE THIS PROBLEM PURCHASING ANY MAGNAVOX REMOTE EVEN IF ITS NOT THE SAME MODEL?
How do I fix my power cycling tv??
I have found that the solder connections get loose where they connect to the p.c.b. please make sure its not plugged in and don't touch the hv probe going to the tube. It will be the last time. Be extremely careful and keep one hand behind your back. If that's not it, the power supply has gone south. Get another TV.
Sep 03, 2015 | JVC LT-46P300 46" 1080p LCD TV - 16:9 -...
I have a Sanyo DP42849 tv and the picture is real blurry almost seems like the picture is in slow motion but the sound is fine. When I shut the tv off it has a good picture for about 30 seconds then it's...
Try resetting, Not sure if this works for your model
Power off the TV, hold down the reset button on the remote and power up the tv with power button on tv while keeping reset depressed.
(Is there a restore factory setting or reset buried in the on screen menu? I couldn't find it in the manual, can you let us know if there is?)
here is the manual in case you don't have it
http://us.sanyo.com/dynamic/product/Downloads/DP42-46849-52449%20(331--)-15947801.pdf
May 15, 2014 | Televison & Video
Won't completely shut off
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Nov 21, 2013 | PixiModo Reflection 15M 15-Inch Digital...
Auria tv "button locked" message.
Holding Vol and Vol- buttons will lock/unlock the buttons. In my case, this didn't completely fix the problem - I was not able to get to many functions. I suspect it was in some store-demo mode. To completely rest, hold the Menu and Chan- buttons then press the Power button (starting from the tv being off). Pressing other button combos will put the tv into manufacturing mode (with cycling solid colors). Turning the tv off and back on will exit this.
Jun 24, 2011 | Televison & Video
My Apple mac book pro will not boot up. I have a grey screen. I've taken out the battery held doen the on button for 5 seconds and re connected it nut I've still got a grey screen. Help
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Apple MacBook Pro Notebook
I've had my Sharp Aquos LC20E1U for a number of years. A couple of times recently it just shut off on its own. It started OK again the following day. However, last time this happened, it wouldn't even...
service menu procedure text changed by midge to work with Sharp LC-32P70E & probably the same for similar models.
There are probably ways of really messing up your set if you do the wrong thing from the service menus, so do this at your own risk:
To enter service menu, make sure the set is plugged in but turned off at the power button on the top of the tv,
then while holding both input button and volume down button, push the power button. Within about 5 seconds, the set will power up keep holding the input and volume down buttons until a small "K" appears in a box on the left side of the screen. Then press and hold the channel down and vol down buttons at the same time to enter the service menu.
Once the service menu is displayed on the screen, you can get the screen to display different levels of solid grey by pressing the number keys on your remote. i.e. press "1" to get a relatively dark grey, 2 for a lighter grey, and so on up to 6 which is a bright white screen; 7, 8, and 9 don't appear to do anything. (this was for adjusting grey levels, other settings are available too) Press any number a second time to return to the service menu...
Not sure wether the grey background settings apply, but for entering the service menu it does.
I think to get out of service mode you have to disconnect the TV from the mains and wait about 30 seconds.
it's some time since I used the service menu on the Sharp Aquos but I do remember you can do a full reset to factory settings as well as turn on, off and reset certain system settings too you will just have to experiment with the remote keys, I think the colour fastext key access different menu levels etc but as I said I am unsure, at least this procedure will get you there so you can try for yourself.
Hope this helps
Please come back to let me know if the service menu procedure works for you.
Good Luck
Midge.
Feb 10, 2011 | Televison & Video
My tv just changes colors when I turn it on with no picture, no of the buttons work on the remote or tv, what is the problem
Your TV is in the service mode. Just try one of two things to correct this. With the original remote, press the cursor button left, followed by pressing the right cursor button. Now shut the TV off. When you power up your TV it should be fine. The second thing to try is to press the cursor button up, followed by pressing the cursor button down. Power off the TV. Now power it up and it should be fine. Thanks for asking and show a few hands of support.
Jan 03, 2011 | Emerson Televison & Video
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Haier HL26R COMCAST REMOTE CODE
what kind of comcast remote do you have please describe, black and silver, dta, and especially important what color is the OK/select button grey or red. If the Ok/select button is red the codes are 11034, 10768, if the ok select button is grey there are no codes, however you can use the search option listed below
step 1 press the tv button located at the top of the remote
step 2 press and hold the setup button located on the upper right of the remote until the tv button blinks red 2 times.
step 3 enter code 991 the tv button will blink 2 times again
step 4 alternate pressing the grey Power button then the tv button located at the top of the remote ( the tv will turn off when it finds the correct code)
step 5 press the Setup button when the tv turns off and the tv button will blink 2 times confirming the code is locked in
FYI this process can take quite some time but there is no direct code listing for the non dvr remotes.
Good Luck
Jun 20, 2009 | Haier HTF20R21 20" TV
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Feb 23, 2009 | Toshiba 42H81 42" Rear Projection...
Magnavox 37MD359B 37 in LCD TV Logo
1,121 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
