Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
My color is gone. The only color that shows is blue. I've already tried manual and auto resets to no avail.
  • Hitachi Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV My color is gone. The - 65af323.jpgluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 02, 2011
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
Limited color on screen primarily blue, white and green. I use to be able to fix by giving the screen a gentle wiggle but color spectrum is gone.
Sounds like you have a bad joint on the tv circuit board somewhere.There is another thing it could be if you have a scart lead connected. Pull it out and check to make sure none of the pins are dissapearing inside the plug. Sometimes they slip inside. Check both ends of the lead.
Feb 16, 2012 | Panasonic TCP42C2 42 in TV
There was an electrical storm close to our home, we had a flash of lightning. Now we can't get a picture to show. The menu works, but nothing from satellite, Wii and DVD. Is there a way to reset...
Hi, You should have unplugged your set in a storm like that. You should have had a surge protector too. I believe you will be looking at a big repair bill. Good luck.
Jul 19, 2011 | Panasonic Viera TH-42PX80U Plasma TV
My Acer AL1717 Screen has turned Blue......I just want to know how to Turn it back to normal colour.....Anyone can Help??
hi,
reset your monitor color setting by the following setting
Press the menu button
Select Reset
press enter
this will reset the monitors color setting to factory default
ok
Jan 19, 2011 | Acer AL1717 17" LCD Monitor
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
